Odd, the flash should fire as long as the shutter activates. Do either of the flashes trigger with another lens?
The flash should trigger in all modes. A non-A lens will only stop down in M, B or X mode. The AF 160 is a TTL flash and will shoot in manual mode (full power) or in Auto mode (two settings) using the built-in sensor.
Non-A lenses will only stop down in M, B or X mode. In all other modes non-A lenses will shoot wide open. This doesn't apply to screw mount or adapted lens as you should be able to stop them down using the aperture ring.
P-TTL is not supported with non-A lenses either. The flash will fire at full power unless set manually or the flash has an auto sensor mode.
Setting the camera to X mode will set the the shutter speed to the flash sync speed of 1/180 sec. You can set a lower shutter speed with the eDial but you can't go over 1/180 sec.
Have you set the camera to enable use of aperture ring?
