08-17-2008, 05:13 AM   #1
1st DL2 AND COBRA 700AF DEDICATED FLASH
Having recently acquired a Pentax 1st DL Digital SLR, I would like to know if it is at all possible to combine my COBRA 700AF Dedicated Autofocus flash unit with this camera. The hot shoe buttons appear to be the same configuration, although when I fit the flash to the camera, the red autofocus lights come on and remain on. Whilst attempting to take a photo, the 1st DL will neither focus on the red light nor flash.
I previously used the flash with my Pentax SF7 SLR film camera OK and it still works with this.
Any suggestions ??
08-18-2008, 05:24 AM   #2
First of all, take the flash off the camera and use multimeter to check the voltage. It should be below 30V (though way less than 25V is recommended). Once you check that voltage is OK, use it in manual mode. TTL mode will not work.
08-19-2008, 01:54 AM   #3
Hi, drabina..........will attempt your suggested solution...will advise
09-07-2008, 09:09 AM   #4
Problem solved
Hi, All.......Having contacted Pentax UK, I am advised NOT to use this flash unit with my 1st DL camera as internal damage might occur.
Therefore, it's up for sale....having purchased the recommended AF-360FGZ
Thanks to all who looked
09-08-2008, 08:55 AM   #5
Spex's Avatar
Hm, according to this page, Cobra 700AF has 4.4V pin voltage, whichi is much less than 30V, which's max voltage for Pentax bodies. So, that mean that you could use it with your DL.
Maybe they in Pentax were not sure about its voltage, so they just said not to use it on default?
1st, autofocus, camera, cobra, cobra 700af, dl, flash, lighting, photo studio, strobist
Dedicated Flash brucethebaldguy Flashes, Lighting, and Studio 1 08-01-2008 05:46 AM
For Sale - Sold: Cobra Macro Flash (ring flash) heatherslightbox Sold Items 2 05-07-2008 07:12 AM
Pentax *ist DL2 and wireless flash Jim Royal Pentax DSLR Discussion 3 09-12-2007 12:54 PM
Is Nissin 5200G flash gun use possible with DL2? Arjay Bee Flashes, Lighting, and Studio 0 04-24-2007 04:23 AM
All times are GMT -7. The time now is 04:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
