Originally posted by kellys Is the Quantum FW57 wireless TTL adapter for FreeXwire compatible with the K1 and K3ii?
It should work on a modern Pentax as well, however, if it works at all then you will only get standard triggering up to the sync-speed.
There won't be any automatic metering support or HSS (high-speed sync).
For HSS (using flash even though the shutter speed exceeds the sync-speed) you will have to use one of Cactus V6II, Acon R930, or Aokatec optical->wireless->optical.
The V6II currently supports HSS (with supported flashes or those that allow HSS to be engaged manually) and will receive an alternative firmware version that will also support P-TTL (automatic metering). The R930 already supports automatic metering but is way less useful when using manual flash control.
