Originally posted by awscreo I can get Vello one to see what difference it will make, it's $15.
Sounds good, but note how the part has become obsolete for anyone who moved on to radio triggers.
Chances are you'll be blowing $15 on a part that will see hardly any use.
Originally posted by awscreo Thing is, I bet holding onto my K-1 plus 70-200 would be a bit of a struggle after an hour or two)
Woah! You'd be holding the "K-1 + 70-200" dumbbell in one hand and a flash in the other. Unless you are Schwarzenegger in the 80's I wouldn't recommend that!
Even just the flash on its own (let alone with a modifier added) gets heavy after a while and if you don't have your left hand to support the lens, the K-1 + 70-200 combo will be dragging you down very quickly.
