Off Camera Flash Optical Slave
Just wanted to portray this scenario:
Pentax K-3II with Cactus V5 trigger, no flash on camera, camera in Manual mode.
Three Pentax AF360FGZ flashes off camera in Manual mode, each of the flashes with V5 triggers, on light stands.
One other flash (4th one), off camera. I will use the Neewer TT560 as a hypothetical example for this flash. In this setup, unlike the other flashes it would not have a V5 trigger on it, but would have its Slave mode set to S1 to react to the single firing of the other 3 flash units.
I am almost certain this is the method that would successfully facilitate the 4th flash that would be reliant on the optical triggering Slave (S1) mode without the use of the radio trigger. I am contemplating a fourth flash, possible choices being the Neewer TT560 or the Yongnuo YN560IV without purchasing more radio triggers quite yet.
My question is whether the above scenario would be effective as far as the 4th flash in S1 mode firing at the same time as the other three flashes.
