08-11-2017, 11:47 AM   #1
AF 540 FGZ acting weird when paired with Cactus V6II
Hello guys,
I havent used my flashes for some time, and when i did, something went wrong.
I have 2 Pentax AF 540 FGZ units, and Cactus V6 II transmitters. For some reason, only 1 of my flashes working properly, the other one, when paird with transmitter, is not firing at all, or firing too late. This flash mounted on the camera works good. On the transmitter it starts to cycle through modes (digital - 35mm - etc). I tried to mount it on different transmitter units, but no success.
The setting on all transmitters is manual: all in Pentax, and flash profiles is 540 FGZ. The setting on the flash itself does not matter, it always acts the same.
Did i messed up with settings somewhere, or i should try to repair that flash?
08-11-2017, 05:33 PM   #2
If the tx, rx, and channel settings are appropriate, the flashes are set to manual mode, and the camera is in manual mode with no set shutter delay it most likely should operate. That would be the basic things to check, unless you already have. If the flash normally fires when mounted on the flash hot shoe with no problem, then it most likely does not need repair.
08-12-2017, 12:59 AM   #3
mcgregni's Avatar
Maybe the connections at the hotshoe need more tightening ....press the base plate firmly fully in with your thumb and tighten the locking lever further.
The flash on the Rx unit needs to be set to P-TTL mode.
af, cactus, fgz, flash, flashes, lighting, pentax, photo studio, strobist, transmitter, transmitters, units
Pentax K30 (Cactus V6ii) + Metz 52 AF-1 (Cactus V6ii) = HSS only ( 1/180+) AldaCZ Flashes, Lighting, and Studio 11 05-21-2017 11:41 PM
Pentax K1 and Cactus V6II and Cactus RF60 on location portrait shoot gsande2016 Post Your Photos! 3 11-09-2016 07:01 PM
Second courtain sync or strobe - Cactus v6II plus any Pentax 360/540 I or II gabriels Flashes, Lighting, and Studio 8 09-21-2016 02:52 AM
Cactus RF60 and Cactus V6II with Pentax K1 gsande2016 Flashes, Lighting, and Studio 3 09-16-2016 02:24 PM
AF 540 FGZ for wireless in concert with the AF 360 FGZ Ed in GA Pentax Camera and Field Accessories 10 05-08-2007 09:45 PM
All times are GMT -7. The time now is 01:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
