08-14-2017, 12:50 PM   #1
Cactus C6 ii as Trigger for Metz Flashes? Is this possible?
Hello
I am not familiar with the Cactus V6 ii!
I have a question? Would it be possible to put an Cactus V6 ii on an Pentax Cameras Flash-Shoe and then remote Fire Metz (Pentax)-Flashes in Servo od Remote Modus.
Are the Remote Channels compatible with the Channels Metz/Pentax uses?
Has someone experience with this combination.
Gérard
08-14-2017, 01:19 PM - 1 Like   #2
pschlute's Avatar
You will need two or more v6 units.....one on camera and one fitted to each flash foot. You can then fire the remote flash/flashes either setting the power manually directly from the V6 transmitter on camera, or by setting the manual power directly on the flashes. The latter method is prefered if you use a flashmeter as it does not fire the pre-flash.
There is no P-TTL mode for the remote flash yet....but is an upgrade in the pipeline. You can also mount another flash on the TX unit on camera and operate that one in P-TTL mode
My experience is with the Pentax AF540/360 so cannot answer for the Metz.
Or get a Cactus RF60X which has its wireless receiver built in
08-17-2017, 09:07 AM   #3
Class A's Avatar
QuoteOriginally posted by Gerard_Dirks Quote
With "Remote Channels" are you referring the the so-called "wireless" channel settings on Pentax-compatible flashes? These would refer to channels used in optical information transmission (the "wireless" system used by P-TTL).
The V6II does not use optical transmission so these optical channels become irrelevant. You can think of a V6II pair roughly as a P-TTL cable replacement. Currently there is no full P-TTL support but a respective firmware upgrade is in preparation.
Currently, you can already remotely control the power-level and the zoom setting of a Pentax compatible flash using a V6II pair. You can also use HSS (but there is no second-curtain sync or automatic metering yet). For all this to work, the Pentax-compatible flash (from Pentax or Metz) must be in P-TTL (HSS) mode (i.e., a standard mode, neither servo or slave modes are required/useful).
The following dedicated profiles for the V6II exists:
Metz 36 AF-5, 44 AF-1, 50 AF-1, 58 AF-2.
Pentax AF 360 FGZ, AF 360 FGZ II, AF 540 FGZ, AF 540 FGZ II.
However, more Pentax compatible flashes are supported through a generic Pentax profile.
I'm using the V6II with a K-1 and a Metz 58 AF-2. Works fine. So far only with manual remote power-level control, but that's my preferred flash control approach anyhow. The soon to be released X-TTL Pentax version for the V6II is expected to fully support P-TTL.
11-07-2017, 02:12 AM - 1 Like   #4
I can confirm that K-5II and K-7 +V6II / Metz48 and 50+ V6II P-ttl HSS works and you can remote control flash power output.
02-24-2019, 12:07 PM   #5
RobSpain's Avatar
Do you know if the update you mention has happened yet? I currently have a Metz 52 AF-1 and a 44 AF-2 and am considering to buy two V6 II units, one on-camera, the other in RX mode. As I understand it, at present, the 52 could be mounted on top of one V6 II unit and in turn on top of the camera and I would have pass-through TTL metering, correct? And manual power and zoom on the other Metz 44 in RX mode, correct? BTW I'm using all of this on a K-70.
02-24-2019, 03:23 PM - 1 Like   #6
pschlute's Avatar
QuoteOriginally posted by RobSpain Quote
The P-TTL update for the Cactus V6II happened many months ago. I have them working very well with off camera Pentax AF540/AF360 and Cactus RF60 flash units in P-TTL mode.
I cannot answer for your specific flash units and suggest you start a new thread specifically on that subject.
02-25-2019, 05:49 AM   #7
RobSpain's Avatar
Many thanks for confirming that.
03-03-2019, 08:30 AM   #8
klaus123's Avatar
Beside other options Metz M400 & AF26-AF1 work together with my V6II
03-19-2019, 04:19 PM - 1 Like   #9
RobSpain's Avatar
Since my last reply to you (on 25th Feb. 2019) I have now purchased two V6 II's, using them in conjunction with my K-70, a Metz 52 AF-1 and Metz 44 AF-2. They only arrived yesterday but I've been at it all day and so far so good. Everything I've tried thus far works, including updating the firmware to PEN.A.005! But I haven't tried everything, as yet. So I will write a new post in a few days on the subject in the hope that it will help other Pentax, and in particular, K-70 owners.
cactus, cactus c6 ii, channels, flash, ii, lighting, metz, photo studio, strobist, v6
Pentax K30 (Cactus V6ii) + Metz 52 AF-1 (Cactus V6ii) = HSS only ( 1/180+) AldaCZ Flashes, Lighting, and Studio 11 05-21-2017 11:41 PM
For Sale - Sold: Pentax K1+50mm 2.8 macro+cactus flash and cactus trigger. wdh1974 Sold Items 7 03-11-2017 08:55 PM
Cactus V6 II with Pentax K3, Pentax K1 + Metz 58 AF-2, Metz 52 AF-1 eriksvec Flashes, Lighting, and Studio 3 02-17-2017 02:38 AM
Quick Question for Owners of Cactus V6 and V6 ii - Can They Trigger Each Other? Ron_Man Flashes, Lighting, and Studio 3 08-29-2016 07:54 PM
All times are GMT -7. The time now is 08:02 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
