Originally posted by biz-engineer How can exposure metering happen without body / flash communication ? I got myself an RF60 and V6 which was supposed to be PTTL , and it isn't.
I think there‘s a misunderstanding. V6 uses the PTTL power signal to remotely but manually setting the flashes light emission. If a PTTL flash does understand analog TTL signals it can be learnd to work in the system by creating a dedicated V6 flash profile. Although a bit tricky I did it for my AF201FG. Some profiles are delivered by Cactus. I guess there isn‘t any significant communication between camera and the V6 units but fire. Unfortunately this system doesn‘t work with my Metz 52 AF-1 pentax version because it‘s fully digital. But it should work with the V6II. I don’t own these items so can’t test.
The V6II system seems to work digital having some real camera system dependent communication. In my understanding the „X firmware“ will especially extend by TTL operation mode and support manufacturer specific TTL HSS features of the flashes. That‘s why for each manufacturer a specific firmware extension is needed. Other systems than Pentax are already supported. The system allows mixing HSS supporting flash units of different manufacturers within such a cactus V6II setup. If there are also V6 units included within the setup they are only manually wireless controlled.
