Originally posted by hatsofe Steve, it didn't fire in any mode at all when manual lens was attached and shatter speed was limited to 1/180s.
Will the built-in flash work with the same lens or with no lens mounted? If so, talk to B&H.
Originally posted by hatsofe Other then that, a flash that cannot match shatter speed higher then 1/180s is of no use to me.
What are you attempting to do? The common use case for HSS is outdoor portraiture in bright light where "ghosting" is the concern and the photographer desires flash for key or fill. The other common use case is for action sports in bright light and moderate distance where supplemental light is desired using shutter speed to freeze the motion.
Originally posted by hatsofe I don't use an auto focus even when it's available. My interest is mostly wild life and these creatures move fast. My average shatter speed is 1/640. I'd love to have A-lenses with 400-600mm focal length but I needed a mortgage to buy them. Third party manufacturers almost don't make anything for Pentax brand, surely not a super tell photo.
I think of trying to modify the lens mount, so it will provide one single aperture value for the camera, let's say f8. I looked into Tamron Adaptall 2 mount and it seems that the camera reads a resistance value in reference to each aperture stop.Just a simple analog signal.
Are you saying that you want HSS for fast moving wildlife? If so, are you aware that HSS delivers a significant performance hit that may severely limit flash range and that HSS flash will not stop motion?
As for modifying mounts...The "A" contacts communicate maximum aperture and aperture range only and that by means of a boolean (bitwise) pattern. Resistance is not part of the equation. For more information...
Features and Operation of the KA Mount | The K-Mount Page
Even if one were to successfully hack the mount (it has been tried by users on this site), the aperture actuator lever movement must be linear to the iris opening, something that is not generally present.
Translation? If one must have the functionality offered by the KA mount on a Pentax dSLR, one must mount KA and newer lenses. There is no hack.
