11-10-2017, 11:24 PM   #1
BruceBanner's Avatar
Portable Studio Suggestions & Equipment
As I continue to learn and evolve with photography so does my desire to try and maximize this small business venture.
I live in a small two bedroom cottage, no sheds, workshops or garages. I've tried small lightboxes before, and I usually feel constrained within the box perimeter, typically I find the backgrounds supplied too reflective as well (and this of course is just photographing small objects and not people.
I discovered black fleece, has excellent non reflective properties and enjoy controlling the light and leaving the object illuminated and the background almost non existent. This sometimes involves having the object being photographed shot with a wide aperture and the black fleece quite far away, so that the background fleece is strongly blurred/bokeh, shadows cast from any lighting would also be reduced due to the distance involved between target and background.
This experience has made me consider how I might approach amassing equipment for a portable portrait style photography rig, with the intention of shooting not objects but people, newborns and even pets.
Large pieces of fleece, white, grey and black with a blackout lining may be useful, and possibly even used out door, but how to hold it up... hmmm...
From what I have learned in terms of small object lightbox photography it might be that I would need very large sheets indeed, indeed if I want the subject a good few feet from the background.
It may be that I would like to offer my photography services 'mobile' and set up in peoples homes and I just wondered if this is already a 'thing' and you should check x, y and z out, or whether a lot of this stuff the client comes to you, to your studio... which I cannot currently offer.
Anyone doing this kinda thing and wants to weigh in with their 2 cents, please wade in
TIA,
Bruce
11-11-2017, 05:32 AM   #2
G.E.Zekai's Avatar
I turned my garage into the studio couple of years back with cheap strobes, home depo wood floor and large white bed sheets. For location work, i have been relying on 5 yongnuo yn 560s.
However, on-location and mobile studio thing seem to be very popular in my area and i rarely use or needed to upgrade my garage studio.
In past 1.5 years, i bought a couple of collapsible backgrounds and they have been phenomenal! Do you need some rustic backdrop? boom, clean white that also works as a reflector? here you go sir. I do carry a couple of "sheets" and home depo wood floors around for baby photos though.
Also recently i stopped and wrote what i need and might need in the future and after doing an extensive research decided to move into Godox system. Haven't received my AD600s yet but the idea of having various strobes, monolights, flashguns all with built-in transceivers capable of doing hss + ttl and can be controlled via the same transmitter seems like a superb idea.
Oh and build some "flags", those black pieces of foam/board help so much when you want to control the light or block a window and practically costs pennies to make one.
11-11-2017, 12:29 PM   #3
Canada_Rockies's Avatar
For on location, inexpensive backdrop stands and backdrops are readily available. I have a set with Black and Blue backdrops that combined cost less than $100 new. Work beautifully. The flash kits I use are an ancient cheap manual set with optical triggers in the heads that I bought from Adorama, including snoots and umbrellas, and I use a flash meter to set the exposure. I trigger with the on board flash or my AF 540. Any inexpensive flash that can be turned down to not affect the exposure will work as a trigger.
background, equipment, object, objects, offer, people, photography, studio suggestions, tripod
Studio shots with no studio equipment wzdevito Photographic Technique 11 04-20-2013 06:02 AM
Good off-camera studio strobe lighting kits? portable... recommendations? JayR Pentax Camera and Field Accessories 2 09-01-2010 07:22 PM
Possible DIY portable Power Supply for Studio Strobes - ADVICE NEEDED MRRiley General Talk 4 09-11-2008 05:40 PM
Photobanks/Portable Drive Suggestions? smcclelland Pentax Camera and Field Accessories 25 08-20-2007 11:25 AM
suggestions on portable back drop holder? slip Pentax Camera and Field Accessories 5 03-28-2007 09:38 PM
All times are GMT -7. The time now is 11:01 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
