Originally posted by BruceBanner What I'm looking for is that one of these flashes does HSS, with a K-1 and KP, can be used as a Slave also in the whole trigger flash thingy majig. I'm also looking to spend the lease amount possible.
So I'm thinking the METZ MECABLITZ 44 AF-2 would be an acceptable backup choice, it's also not too expensive. From what I gather what it can't do is LED for video, but that's ok.
So can anyone weigh in here and advise me, is this choice ok? Or is the M400 worth the extra price? What does it have over the 44?
Originally posted by UncleVanya Also the 44 AF-1 wasn't able to do mastering mode on P-TTL - does the AF-2 version?
I think the Metz 44 AF-2 is a totally acceptable backup AND it does have an LED light for video.
The advantages of the M400 include:
a) Variable power down to 1/256 vs. 1/64.
b) Bounce head from -9 to 90 degrees vs. 0-90 degrees
c) Swivel 360 degrees vs. 300 degrees
d) Max recycle time as slow as 3.2 secs vs. 4 secs.
e) 3 wireless groups vs. 1 wireless group
f) 220g vs. 306 grams (and smaller)
g) The video light has 6 different levels vs. 4 levels & I think stronger at 100 lux max output.
The advantages of the 44 AF-2 include:
a) about $50 less expensive
b) more powerful guide number of 144 vs. 131
I have the 44 AF-2 and personally, I don't need any of the additional features of the M400 and prefer the higher power for bouncing the flash.
UncleV: The 44 AF-2 still does not work as a master; only as a slave as is the case with the M400. Need a Pentax flash if an external is needed as a master.
