11-12-2017, 08:41 AM   #1
HSS with trigger only signal (e.g. P67 + Cactus)
I'm wondering is there a way to go past older cameras fastest sync with new HSS flashes? E.g. P67 with its 1/30 without going to leaf shutter lenses.
I'm thinking of somehow the radio trigger giving the HSS signal towards the flash. Tried to read the manuals, but can't figure out how would it go.
I've got Cactus RF60'ies and Cactus V5 and V6 triggers. Can invest in V6ii (or any other system) if this helps anything.
11-12-2017, 11:23 AM   #2
klaus123's Avatar
The only way for these cameras is the use of LS-Lenses or permanent (Halogen/LED) light instead of flash light
From my experience a distance of 3 stops between ambient and flash light is enough to be ok even with 1/30 of a second for most subjects
11-12-2017, 12:26 PM   #3
Hmm, interesting..
Maybe I should say my real target, which is the old Graflex camera with a focal plane cloth shutter. Just used P67 as the example, as were in Pforums, heh. Thinking of how to combine flash with this guy. Its slowest time (largest simultaneous exposure to the film) is around 1/10sec, and now I'm thinking of is there a way to use modern flash with this.
The old timers used flash which burned for all the time. Maybe need to start hunting for some long-burning magnesium..
11-12-2017, 05:25 PM   #4
I believe there are leaf shutter equipped p67 lenses as well. Set the body to the sync speed or slower, trigger the flash off the pc port on the lens iirc.
11-16-2017, 06:21 AM   #5
Class A's Avatar
QuoteOriginally posted by ppohja Quote
An HSS-capable trigger only helps, if the camera supports P-TTL.
The camera needs to provide a pre-sync signal. Without that, no trigger can initiate an HSS flash quickly enough.
If your camera supports cable (electronic) shutter-release, you could try the "starter pistol method". That would require three triggers, but does not depend on P-TTL.
11-16-2017, 08:35 AM   #6
Okey, something along these lines was that I was looking for. Thanks!
11-21-2017, 07:55 AM   #7
Wheatfield's Avatar
No. Flash sync is a product of the speed of the shutter curtains. High speed sync as available on some more recent cameras is timed flash pulses as the shutter slit traverses the image plane. Cameras like the 6x7 lack the required circuitry to enable this.
I found with the 6x7 that the low sync speed wasn’t an impediment in the studio, and outdoors I used reflectors rather than flash so the slow sync speed wasn’t an issue. Eventually I did get both the 90 and 165mm leaf shutter lenses, but as often as not, I still used reflectors outdoors as the light was more predictable.
cactus, e.g, flash, hss, lighting, p67, photo studio, strobist
Pentax K30 (Cactus V6ii) + Metz 52 AF-1 (Cactus V6ii) = HSS only ( 1/180+) AldaCZ Flashes, Lighting, and Studio 11 05-21-2017 11:41 PM
Starting to test Godox HSS with Cactus V6ii, HSS works in AV mode? jake14mw Flashes, Lighting, and Studio 6 04-13-2017 07:30 AM
P67 400mm EDIF + P67 TC or E-mount TC? Paul MaudDib Pentax SLR Lens Discussion 6 09-23-2015 01:06 PM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
All times are GMT -7. The time now is 02:23 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
