I bit the bullet and took a risk on pairing the battery-powered Orlit Rovelight RT 601 500Ws HSS (non-TTL) Monolight/TR-Q6 Trigger kit with the Cactus V6ii to see if it would work...glad I did. HSS works perfectly up to the max mechanical shutter speed when mounted on my KP.
The Orlit Rovelight RT 601 kit (including a TR-Q6N or TR-Q6C trigger) can be purchased new for $379 from Adorama. A used “like new” Cactus V6ii can be purchased for ~$64 (a new one runs $95). This setup is a steal considering you are getting a 500Ws battery-powered monolight and full wireless control.
I knew people had experienced success with the Cactus when paired with other more expensive monolights (Profoto, etc.), but I could not find where anyone had posted on the Orlit.
Like the other examples on the forum, the Cactus essentially acts as a translator when mounted on the camera hot shoe between the Pentax body and the Non-Pentax (Nikon in my case) trigger. With the newly-released Pentax-specific firmware installed, the Cactus automatically detected the Pentax camera and Nikon flash trigger.
V6ii settings: Tx, Pentax camera profile, Nikon flash profile, Normal HSS mode
TR-Q6N settings: Manual flash, HSS
RT 601 settings: wireless mode “TTL-N” for Nikon; HSS automatically enabled by TR-Q6N
I imagine this would work the same for the TR-Q6C (Canon) if you select “TTL-C” as the wireless mode on the RT 601. However, I don’t have a Canon version to test.
The Orlit TR-Q6 triggers allow for full control of the RT 601 including flash output, sync mode, modeling light, etc. The TR-Q6 also features bluetooth, which allows you to adjust the settings from a smartphone app for a wireless tethering experience. I haven’t tried that feature out yet, but it is on my to-do list.
