Originally posted by Hattifnatt What solutions do I have if I want to radio trigger an AD4000 PRO or AD600 PRO from a K-1? I don't need HSS or TTL, I just need to trigger the flash. I know ideally I would need the Xpro-P but it's not on stock and I need it until tomorrow. Any other trigger that I can use?
Hello,
If you are in a hurry, and just need a cheap trigger, a XT16 should be enough. This trigger supports the Godox X protocol so it will fire your AD400/AD600 pro without issue. Also the XT16 is quite cheap. An XT32 version (for example, Canon version) should work too. I have one of these (XT32C), and I can trigger all my Godox devices (ad200, ad360, v850). But the XT32 is a bit more expensive. Even an old 433MHz FT16 with a couple of FT16R receivers should work. You can connect the FT16R receiver to the USB port, and you are done. Any Godox trigger will allow to control power remotely, too.
No Godox triggers also can fire your AD400/AD600, you just need to connect the receiver to the 3.5mm sync port of your flash. I tested this kind of combination with yongnuo triggers (rf602/rf605) and my AD200, and it worked. Of course, you lose remote power control in this case.
Regards.
