Lighting gurus...
I am making my first foray into studio lighting. I have purchased a simple (non-TTL, non-HSS) 150 Ws strobe. My question here regards optical triggering.
Some cheapo radio triggers are likely in my future. But I'd still like to understand the optical triggering process first. Here's the scoop:
1. Using the on-camera flash (K-30), I can get the strobe to fire through optical triggering. I set the wireless flash mode to control, rather than master. It works, but due to a
known issue of the on-board flash timing, some fraction of the on-board flash still appears in the pictures.
2. In order to eliminate issue #1, I mounted my Metz 52 to the hotshoe to use as a trigger. I set the Metz to Control mode. It fires the strobe, but the strobe lighting does not appear in the photo, as though it is firing a pre-flash for p-TTL, even though it's not in TTL mode. So, what gives? I actually thought something might be wrong with the strobe, but putting the Metz in "M" mode works! Of course, the Metz light now appears in the photo, too. I can dial it back to 1/128, which might be fine, but I'd still like to get it to work properly.
So, the short version: Why can I properly trigger the strobe in "M" mode of the hotshoe flash but not in Control mode? How do I optically trigger the strobe without the hotshoe flash also appearing the photo?
Thanks!
