Originally posted by kaseki Perhaps I have a misunderstanding, but I thought that TTL flashes from the '80s and '90s operated by being triggered by the camera hot shoe, and then flash lamp quenched by another signal on the hot shoe within some 10s of microseconds after flash initiation.
That is basically true...see below...
Originally posted by kaseki I should add that it may be that the AF-500FTZ does not actually get a quench signal from the camera
Its duration is quenched by the body.
Originally posted by mcgregni The older film era TTL system uses a dedicated light sensor inside the camera that detects sufficient exposure directly "off the film plane". Once detected then the quench signal would be sent through the hotshoe
Basically, yes.
OTF/sensor TTL flash measures the
cumulative exposure* and quenches the flash once enough light has been detected from all sources, both ambient and flash. (Flash duration is determined in real time.) Digital TTL and analog TTL protocols do the same thing only using slightly different means.**
P-TTL, OTOH uses a preflash to calculate flash duration in advance. TTL is pretty much foolproof, but requires a more complex camera. P-TTL, however requires no second meter circuit and also allows for easy support for stuff like trailing curtain sync, HSS, flash EC, and wireless metered flash. Note that multiple flash setups for traditional TTL use wired sync and dedicated cabling.
Originally posted by mcgregni Stevebrot's post contained the most hope, maybe he can clarify whether its worth trying the flashes with V6 units for remote manual control .... ?
I was just linking to @awaldrum 's previous post and have never tried it myself. This much we do know; the AF500FTZ will be full manual (duration set at the flash) when used with the V6 triggers since the flash does not support analog TTL or digital P-TTL.
* Not the same as instantaneous scene brightness.
** Analog TTL fires the flash with the center contact while keeping the "mode" pin "low" until exposure is sufficient (passive control). Digital TTL also fires using the center contact, but quenches using an explicit command (active control) through the digital data pin on the hot shoe. Digital TTL protocol is a bit of a misnomer since it is more properly digital dedication protocol that allows the body a fair amount of setup control prior to actual firing.
