Hi.
Some of you will have seen a similar post where I was using the older Godox FT-16 trigger.
This is an
instructional thread not intended for comparing setups or systems.
I have since acquired a Godox XT32N trigger so thought I would again provide step by step instructions to achieve HSS using a Pentax DLSR with a very similar setup. So far my testing is only with a K1 but I'll provide more info once I test with my K3.
This thread to is an
instructional on how to achieve hss with equipment I will outline below. Note: If you only need flash sync speed at 1/200s or less for the K1 and 1/180s or less for the APS-C DSLR's you can forego the Cactus V6 II.
If anyone wants to compare setup x vs setup y and the plusses and minuses I suggest they start their own thread with that intent.
This threads intent is "
instructional" on how to use said equipment. This is to
help people use the said equipment if they are having issues getting it all working together.
Please note that in the equipment list I am using the older Godox Ving 850 Mk I which does not have an integrated receiver. The new Mk II has the receiver built-in. The great thing is that Godox included forward compatibility so that by plugging in the XTR16S the Mk I flashes can continue to be used with their now expansive 2.4GHz triggering system.
Equipment List
1 Pentax K1
1 Cactus V6 II
1 Godox XT32N trigger
1 Godox Ving 850 Mk I flash
1 Godox XTR16S receiver (Note: This is not required if you purchase a Godox Ving 850 Mk II flash)
Godox XT32N Trigger
Based on some other posts I thought I may have to cover some pins on the XT32N trigger with some tape. I am happy to report this is
NOT required. My only explanation is that maybe the current firmware on the Cactus V6 II (1.1.013) resolved some kind of issue. I am guessing here.
Setup Instructions
1. Update firmware on the Cactus V6 II to 1.1.013 (this is a once off task)
2. Mount Cactus V6 II trigger in camera hotshoe
3. Mount Godox XT32N trigger on the Cactus trigger
4. Set sync mode to Normal HSS (on Cactus V6 II trigger)
5. Set Camera System: Pentax (on Cactus V6 II trigger)
6. Set Flash System:
Manual Flash (on Cactus V6 II trigger)
7. Set HSS mode on the Godox Ving 850 Mk I (long press the 3rd button under the LCD)
8. Plug the Godox XT16S into the Godox Ving 850 Mk I.
The steps in images to help anyone else who may try this are at the bottom of the post.
Good luck and enjoy having HSS with fast recharge times, wireless manual control (Godox XT32N trigger) of the flashes and expandability options with the wider Godox flash system.
Cheers,
Howie Be
---------- Post added 02-28-2018 at 02:46 AM ----------
Hi.
Here is the final image on setting the HSS mode on the flash as it was not included.
Howie Be
---------- Post added 02-28-2018 at 02:51 AM ----------
Final image setting HSS mode on the flash.
