I do recommend some general study and reading up on flash photography before expecting to get good control over things, and to expect consistent results. Certainly for an event this prior knowledge is going to be needed.
The flash has a range of outputs that it can provide .....a minimum and a maximum, plus many steps in between. The actual brightness effect these outputs have on an image, as recorded by the camera sensor, depend on the ISO, Aperture and the distance from the subject. If any of these factors causes the minimum/maximum limits to be exceeded, then the flash is unable to automatically adjust itself any further. The automatic metering is likely to be inconsistent also when the flash is working at these limits.
I always recommend a fixed ISO for flash work. At small distances indoors then ISO 200 should be your maximum ISO, or 100 if you are shooting at very wide apertures. Try again and put this into practice and see the results.
If we are wanting to get more ambient light recorded into the mix by using a higher ISO, then we will likely have to take steps to increase the effective flash to subject distance, such as by bouncing the flash ....this gives nicer looking light also.
You will find plenty of information to help in my “Pentax Flash Guides”, downloadable from my signature below my posts. Even though the focus is on the Pentax flash models, you will find a lot of relevant information about the Pentax flash system and general flash operations that will apply to using your Shanny model.
