03-15-2018, 07:42 AM   #1
K1 & Neo II Rotolight
Are any of the K1 users using a Neo II Rotolight ? If so, how is it working for you ? Did you have to purchase a transmitter or X-flash sync cord ? How is the HSS working ?
Thanks
Fred
03-15-2018, 08:58 AM - 1 Like   #2
Otis Memorial Pentaxian
The K-1 uses the same flash protocols and has the same restrictions as other recent Pentax bodies. A significant restriction related to HSS is that the camera provides NO sync above the x-sync speed unless a P-TTL flash or trigger in HSS mode is detected on the hot shoe. The Neo 2 only supports this feature with wireless trigger. The details of how the Neo 2 works with Pentax for this are in the user manual.
https://www.rotolight.com/pdf/neo2-usermanual.pdf
03-15-2018, 10:22 AM   #3
pid
as far as I see it you need the Cactus VI HSS Tricker to shoot HSS with Rotolight. Right?
03-15-2018, 10:45 AM - 1 Like   #4
BigMackCam's Avatar
Moved to Lighting forum, as this is pertinent to owners of other camera models too
03-15-2018, 09:41 PM   #5
Class A's Avatar
Typical downsides of LED-based lights like the Rotolight include insufficient power and uneven spectra.
Even a good CRI value does not guarantee good colour reproduction as the standard CRI figure is based on a not very discriminative test using rather unsaturated patches.
I'd therefore recommend to make sure that you are happy regarding these parameters. Personally, I would not trust the vast majority of YouTube channels presenting such products as they have a tendency to talk up gear like this. They never mention the shortcomings, only implicitly when a new version is available with increased specs. Then, they'll mention that doubling the power output is a much needed improvement, but in the review of the predecessor, a lack of power has never been a discussion point...
03-16-2018, 06:00 PM   #6
Thanks for the info, that was quite helpful .
Fred
dslr, full frame, full-frame, hss rotolight, ii, k-1, k1, neo ii rotolight, pentax k-1
HSS sync with Rotolight AEOS ? zobeleye Pentax Medium Format 3 10-09-2017 04:23 AM
Anybody using continuous LED Fiilight or Rotolight Neo etc... tomO2013 Flashes, Lighting, and Studio 3 05-13-2016 12:52 PM
People My son in studio with Rotolight igabc Post Your Photos! 3 10-15-2015 04:33 PM
Full Frame Neo-Spotmatic? Nesster Pentax Full Frame 79 09-10-2013 09:59 PM
Neo - Classical Architecture paulyrichard Post Your Photos! 3 05-24-2009 12:43 PM
All times are GMT -7. The time now is 07:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
