Originally posted by honey bo bo Did you even look at the above photo and the Exif .
Yes of course I did ..... The point is there is nothing in the image or the available EXIF that proves it was taken in 2nd Curtain Sync mode, as Brian has also said.
Do you have more detailed Exif available that shows the sync mode?
The point I was making before was that in shots such as your one with the little boy, it probably makes little difference.
Brian, I haven't tested this, but I suspect that if 2nd curtain is set but with a time value beyond 1/90th then the flash will just flick out of 2nd curtain mode ....I think the image would still be taken
