Originally posted by mcgregni I'm not sure if we should categorise any particular event (eg weddings) as being suited to one or another type of technical triggering approach .... ?
My point was about moments that cannot be repeated and accepting a responsibility to capture once in a lifetime events, not for yourself, but for someone else.
We can debate which technology is best for that, but that some applications call for the best technical solution you can muster shouldn't be up for debate, right?
The mere fact that someone/something out of your control can interrupt a line-of-sight path, e.g., by simply blocking an optical sensor temporarily by walking by, that the sun could suddenly start interfering outdoors, etc. would suggest to me that this approach is less reliable than using a reliable radio triggering technology. It is possible that radio transmission has other Achilles heels, e.g., radio inference, but in my view if radio inference has been excluded through a test, it is very unlikely to become an issue during the event, in contrast to the vagaries of optical triggering. Just my view.
BTW, you yourself mentioned the need for "
careful positioning and turning of the slave flash head" in some circumstances when using optical triggering. Personally, I would just eliminate that need, independently of whether or not optical triggering can be as reliable as radio triggering in controlled circumstances. One thing less to worry about.
Assuming that one's master flash is on a camera which can move and change rotation quite a bit (unless mounted to a tripod) even when you just change from portrait to landscape orientation, I wonder how realistic it is to reliably hit optical receivers in less than straightforward settings. No doubt optical triggering has many applications in which it is just fine, but in my book some of its limitations are just not worth bothering with in more demanding applications.
Originally posted by mcgregni These potential negatives would include greater complexities in configurations / things that can be set wrong / more learning to do in advance to ensure perfection .
I am assuming that one is competent regarding the gear one is using. Anything else would be negligent, if you are going to capture important images for someone else.
FWIW, I don't agree that there are "greater complexities" involved using radio triggers. Cheap ones require no configuration at all and all of them (cheap or not) work very well with default settings. Perform a factory reset, if you feel that you've tried something fancy and did not succeed. Note that Pentax's way of configuring the wireless channel on flashes is not intuitive at all and may not necessarily work with third-party products like the Sigma flash, given how non-standard Sigma flashes behave in other ways.
Anyhow, I'm not here to engage in a "optical" vs "radio" fight. I feel that my input was adequate and helpful and the OP appreciated it twice. So no point in losing focus by engaging in technology fights, OK?
