Show Printable Version 17 Likes Search this Thread
04-15-2018, 02:54 AM   #1
Getting first external flash
Hi all
I hope you don’t mind the message. I have been looking at various threads on the forums and getting some good information.
I’ve only ever used the built-in flash on my K-r. However, I’m now very interested in learning how to use an external flash. I’ve found some excellent resources online and in print.
My budget is pretty limited, so I thought I might get the Yongnuo 585ex model.
I just wanted to check whether more experienced photographers than me thought that might be a suitable one. Basically, I’m not looking for a studio set-up, I’d just like to be able to bounce the flash and get better pictures (I shoot at music events in low light) with a single flash (presumably attached to the camera).
Any thoughts would be gratefully received.
Thanks
Si
04-15-2018, 04:17 AM - 2 Likes   #2
photocles's Avatar
I can also enthusiastically recommend the Cactus RF60 and RF60x flash units. I have the former and it's a very capable flash for the price. The added advantage is that you can also buy a Cactus transceiver (which is pretty inexpensive) and use the flash off-camera very effectively.
04-15-2018, 04:58 AM - 1 Like   #3
You may want to check extensive guide written by one of forum members. The key question is whether you need automatic mode, and music events seem to require it. As per Yongnuo, I have manual one (560 IV) - it works fine, and build quality is good. The only drawback is power consumption, which is definitely higher than in 560 FGZ.
04-15-2018, 06:29 AM - 1 Like   #4
QuoteOriginally posted by Popty Ping Quote
I bought a 585 Yongnuo about a year ago ($65.00 USD ) and have used it a lot on camera and as a slave. 2 of my Grand babies have found the test button and they also use it a lot . So far no problems.
First Photo - Yongnuo585 on K3 set to Bounce with reflector panel extended.
Second Photo - 585 is slave= SP (set to bounce) to Built In (master) on K-3
04-15-2018, 07:27 AM - 1 Like   #5
AlwaysAl's Avatar
Hi all
Si
I've shot rock style music events and, to be honest, lots of fast action, not a lot of good flash-bounce opportunities...seemingly always a dark environment. What works for me is higher ISO, watch and try to work with the stage light patterns for upper body light and use the flash for fill in the lower areas.
At these events, actions is fast and I find there's a need to shoot many times as quick as the flash will recharge (hoping for that perfect capture). So, if this is your environment, make sure your flash recovers quickly and doesn't excessively eat the batteries. On the battery front, found the "black" Eneeloops worked best...shoot a whole night with one set.
Additionally, found that some flashes, in those machine-gun style shoots, the capacitor overheated and recovery slowed potentially missing shots and definitely affecting any learned stride with respect to the lights. Initially, this is what brought me to the Eneeloops (the other batteries would come out too hot to hold) assuming it was the batteries breaking down and overheating the flash. The Eneeloops didn't get hot and quickly realized it was the capacitor.
Next thought was it might have been my flash was worn out but in research to find a replacement discovered this was almost a common phenomena with consumer grade flashes. Finally settled on a Metz and I can hammer away all night and it never even breaks into a sweat. At the time, the off-shore flashes were not readily available so never ventured to testing them although if I was to do it again would definitely consider these options.
Al
04-15-2018, 09:06 AM - 1 Like   #6
The Yongnuo YN585EX is a really nice flash. I have one along with my three Pentax AF360FGZ flashes. It has P-TTL which I have tested, and it works very well. I would recommend it.
If you ever decide to use more than one flash (off camera), I would also recommend Cactus radio trigger products, V5, V6, and so on. I have the V5 type and they do an excellent job.
Pertaining to power, you will most likely not be shooting at full power with your flash, so a set of batteries will usually yield quite a few shots. I use EBL rechargeables, even the AA batteries from a dollar store will give you quite a few shots.
04-15-2018, 10:09 AM   #7
macman24054's Avatar
QuoteOriginally posted by C_Jones Quote
I have the same flash inventory and love my 585ex most of all for the more light output and the tilt and swivel head. I also second the EBL aa batteries as I have been using them for about 2 years with no issues. I also second the Cactus triggers.
04-15-2018, 12:33 PM - 1 Like   #8
Folks
Thanks so much folks. Really interesting information.
Did see that guide to Pentax flashes a forum user wrote - very detailed. Will read more thoroughtly ASAP.
Think it’s going to be good fun getting to grips with this area of photography.
Thanks again - really appreciated!
Si
04-15-2018, 01:29 PM - 1 Like   #9
Alex645's Avatar
For the price nothing new comes close to the Yongnuo 585EX as a great first flash choice.
Just beware of a few drawbacks compared to the Metz Mecablitz 44 AF-2 ($230) or the Pentax AF360FGZ II ($430):
a) Slow recycle time:
Yongnuo: 3-5 seconds
Metz: .1-4 seconds
Pentax: 1.5-2.5 seconds
b) Weight:
Yongnuo: 370 grams
Metz: 306 grams
Pentax: 290 grams
c) Built-in light for video:
Yongnuo: No
Metz: Yes
Pentax: Yes
d) Weather sealed:
Yongnuo: No
Metz: No
Pentax: Yes
On the positive side, it is the only one with a PC sync terminal and has the highest GN (guide number=light output) of the three (190ʻ vs. 144ʻ and 118ʻ). If the bottom line is your budget, the Yongnuo is essentially your best choice.
04-16-2018, 05:27 AM - 3 Likes   #10
Thanks all
Have bought the Yongnuo.
Really looking forward to giving it a go. Hoping that, in time, it will take my photos up a level.
04-16-2018, 08:27 AM - 1 Like   #11
QuoteOriginally posted by macman24054 Quote
I agree that the equipment does a nice job.
---------- Post added 04-16-18 at 11:33 AM ----------
Thanks all
Nice step. It should be interesting for you to be able to learn using an excellent flash such as the YN585EX.
04-16-2018, 11:35 AM - 1 Like   #12
I really feel you will not be disappointed.
04-17-2018, 12:57 AM   #13
Thanks for the latest replies folks.
AlwaysAl - meant to say thanks for the event-specific advice. Thanks to you and Honey Boo Boo for sharing the nice photos too.
I use Eneloops in my K-r, so I will get some more of them.
04-17-2018, 02:25 AM   #14
Alex645's Avatar
Good idea: As you may or may not know, and I canʻt explain to you the science of why, rechargeable batteries will give you a faster recycling time from flash to flash vs. disposable batteries. Of course, you wonʻt get as many flashes per charge as you would an alkaline or lithium cell, but the time for the flash to be ready for the next flash after discharging the previous one is faster.
Rechargeable cells have slightly lower voltage but higher amps which apparently fills the capacitor faster. Ready, aim, fire.
04-17-2018, 05:28 AM - 1 Like   #15
Didn’t know that - thanks for the info.
body, cactus, camera, firing, flash, flashes, hss, light, lighting, photo studio, pm, radio, receiver, sensor, strobist, system, trigger, triggers, v5, yongnuo
Getting Better Flash Bursts: Godox li-ion vrs external battery pack Doundounba Flashes, Lighting, and Studio 107 10-01-2018 02:30 AM
Does the built in K5II flash adjustment effect an external flash? jab2980 Troubleshooting and Beginner Help 3 02-22-2016 02:02 PM
Travel external order and external disorder there's only the seeming phenomenon zztopd Post Your Photos! 11 02-17-2014 09:47 PM
Using Built in Flash in Wireless mode with External Flash i.e AF-360fgz disco_owner Flashes, Lighting, and Studio 7 05-16-2012 07:41 AM
First post with external Flash (3 img) jshurak Photo Critique 5 12-27-2007 04:20 PM
All times are GMT -7. The time now is 02:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
