So it appears that I've busted the power connector on the cable linking my Godox AD180 flash to my PB960 battery pack. The adapter at the flash end of the cord broke off and stayed inside the flash. This is what it now looks like - notice the bare metal leads on the unplugged cable:
As you may or may not know, this flash has no internal battery, to you
have to use it with the battery pack. I've been looking for a replacement cable, only to find that
apparently Godox have changed the shape of the connector in their flashes!
(Why would they do that?!) So, what I have is apparently the "Version 1" plug, and the cable with that connector appears to have become rarer than hen's teeth. I emailed a couple of Ebay sellers who made references to the V1 plug in their listings, but didn't show any in stock (
example). We'll see how/if they answer. A store in Australia claims to have
one old style cable in stock, but won't ship internationally...
As you can imagine, I'm not too keen to have bare metal electrical leads connected to a high power battery pack just dangling in my packpack. So for now, I'm inclined to use electrical tape to semi-permanently fix the cable to the flash and carry on that way while I can (the other end of the cable is fine as of now). But I'd like a more permanent solution. Am I out of luck? This was a fairly expensive flash! It would be rather annoying to have it rendered useless because of a missing cable, while the flash itself is still fully functional!
Soooo... Any thoughts/advice on what to do?
