06-20-2018, 03:28 AM   #16
chrism888's Avatar
" did you mention the Cactus V6II Trigger with the Cactus RF-60 X? P-TTL and HSS "
This would be my recommendation !!
06-20-2018, 05:13 AM - 1 Like   #17
bdery's Avatar
The main advantage of the 540 II is the weather resistance. To a lesser extent the video LED.
I prefer the interface of the Metz 52 AF-1 (I'm guessing you are referring to that one). It's cheaper, more compact, and easier to operate. I suggest you read this review, where I compare the 540 I with the Metz. You'll see what I mean
Metz 52 AF-1 Flash Review - Introduction | PentaxForums.com Reviews
06-20-2018, 11:14 AM   #18
j0n4hpk's Avatar
Being there; suffering that. If you don't mind to work with used equipment, try KEH for earlier Pentax, Metz and other makers flash units. Before committing to buy, try downloading the manuals for the units you select to get and idea of how they'll work with your camera.
06-20-2018, 12:34 PM   #19
Wasp's Avatar
I have the AF360FGZ. It is a pretty good unit and works well with my Pentax bodies. The dead doesn't swivel for bouncing when holding camera vertically but I can work around that.
The worst feature is the lack of memory for settings. The thing powers itself off after a few minutes of non-use to conserve the batteries. That is a good idea, except that upon powering up again you find yourself in PTTL mode, no matter what you had set up before. This is a real drag when you use it on a non-Pentax camera and you have to dial in everything from scratch.
07-02-2018, 08:59 AM   #20
One other thing. How about LED lights? Would they work ?
07-03-2018, 04:54 AM   #21
bdery's Avatar
QuoteOriginally posted by LarryGE Quote
The colour temperature is not the same, the output power is not as high, the light spectrum is not as broad (and the filters on the sensor sometimes have trouble coping with that, leading to inaccurate colours), so it's hit and miss. LED lights can serve but do not replace a strobe.
07-03-2018, 05:03 AM   #22
clackers's Avatar
Very, very weak, any that you'd be looking at.
07-03-2018, 09:34 AM   #23
Looking at the Flashpoint budget studio monolight flash, 120 watt seconds. open for ideas. I want to to stay light and portable.
07-03-2018, 11:18 AM   #24
mcgregni's Avatar
For what specifically? ..... That's really the crucial bit you missed out.
07-03-2018, 11:28 AM   #25
clackers's Avatar
This is mains powered and sits on a stand, not your camera.
For a studio.
07-03-2018, 11:47 AM   #26
retired sw engineer
reh321's Avatar
QuoteOriginally posted by LensBeginner Quote
Have you considered manual flashes?
Light-wise they are the most bang for your bucks, if you don't need P-TTL and HSS.
P-TTL has never worked that well for me. Sometimes I use an "automatic" flash {flash measures light instead of having camera do it} dating back to 1987-1995, when I used my Super Program to photograph my infant daughters, and sometimes I use my Canon flash in purely manual mode. Honestly, though, I don't use flash very often .... in most cases natural light works better for me.
07-03-2018, 02:01 PM   #27
BigMackCam's Avatar
QuoteOriginally posted by reh321 Quote
P-TTL is great for when you're shooting "situations", rather than taking time to get the lighting just right. You still have to put some thought into it, and make flash / EV adjustments if you've time to do so, but it can produce fairly reliable results in situations where a manual flash would simply be impractical. But I far, far prefer using my cheap, all-manual flash units when the situation allows
Of course, most P-TTL flashes (except for the very base models) allow full manual control too, so if funds allow it's worth having one or more of these...
07-03-2018, 02:43 PM   #28
retired sw engineer
reh321's Avatar
These days, I use flash most often for situations around home, and for those I bounce the flash off the {white} ceiling and light up the whole room. The only "trick" here is figuring out what settings are needed, but once I figure that out, I can use the same settings almost any time.
07-03-2018, 03:53 PM   #29
clackers's Avatar
Just as in Manual mode you tweak the power level so you get the contribution to the scene right, you do the same with the Flash Exposure Compensation dial. It's pretty easy.
07-03-2018, 07:20 PM   #30
Mikesul's Avatar
But, for me at least it takes some test shots.
flash, lighting, pentax, photo studio, strobist
Abstract how to control morning burn? inder81jeet Photo Critique 9 07-05-2017 10:54 PM
drill baby drill or burn baby burn.. jeffkrol General Talk 25 07-02-2010 02:16 PM
Anyone with money to burn: A* 135/1.8... amateur6 Pentax SLR Lens Discussion 7 11-29-2009 08:09 PM
Money I don't have on things I don't need daacon Pentax SLR Lens Discussion 5 12-13-2007 10:04 PM
All times are GMT -7. The time now is 12:10 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
