07-03-2018, 10:41 PM   #31
Otis Memorial Pentaxian
clackers's Avatar
But, for me at least it takes some test shots.
So does manual mode, Mike, where you might begin at 1/8 power and iterate from there. Same currency too - stops and half stops.
07-04-2018, 07:22 AM   #32
Mikesul's Avatar
Exactly. If you want to have good control of the light manual mode is essential with some tests.
07-05-2018, 07:29 AM   #33
QuoteOriginally posted by mcgregni Quote
For what specifically? ..... That's really the crucial bit you missed out.
Just looking for a 3 light setup something portable and Light that I can use for the grandkids and for once in awhile some light portraits with the family.
07-05-2018, 07:52 AM   #34
CarlJF's Avatar
QuoteOriginally posted by LarryGE Quote
I would recommend one P-TTL flash, that can be use both on camera in P-TTL for "environmental portaits" (like kid's birthday, family reunions...) or casual shots, and also off camera in manual mode for studio work or more formal shots in a multiflashes setup. The Metz 52 is a great flash for this at a decent price. The other two flashes can be cheap manual ones, the more powerful you can afford.
For the three flashes setup, you will also need a set of triggers to fire and sync these flashes. The Cowboy Studios ones are amongt the cheapest for this, very basics but work just fine in a fully manual multiflash setup. You will also need some additional accessories, like lightstands and umbrellas or lightboxes to make it worth the trouble of setting up a three flashes setup.
07-05-2018, 06:58 PM   #35
clackers's Avatar
If you don't mind not being able to shoot at 1/200s or faster, Larry, just about the easiest way to do that is three Yongnuo 560 flashes and a 560 TX controller for them that sits on your hotshoe.
07-07-2018, 10:16 AM   #36
I have a youngno 585 EX now. I was thinking about the Pentax 540 which would give me also HSS. Will to work together.
07-07-2018, 11:21 AM   #37
Mikesul's Avatar
Shanny SN600FGZ P-TTL HSS Flash costs less and is both powerful and has PTTL and HSS.
07-07-2018, 02:01 PM - 2 Likes   #38
mcgregni's Avatar
Unfortunately we are plagued by a frustrating lack of full compatibility between the various Pentax and third party budget P-TTL models ....If only they all "worked together" fully then life would be much easier (and cheaper).
The Yongnuo 585EX has the P-TTL Wireless functioning, as a slave, but not HSS .... so it can be used as a P-TTL slave controlled by a suitable "Master / Controller" flash (eg AF-540FGZ/II), but we can't buy two of them and get this wireless functioning.
In the case of the Shanny, it gives on-camera HSS, but no P-TTL Wireless. So people are left digging around wondering about triggers. IF you have to use two V6II units, that defeats the purpose of saving money buying the flash!
What we need is a "Shangnuo" model, that's has it all, and still for under $100
07-07-2018, 05:16 PM   #39
Mikesul's Avatar
+1 to that!
07-07-2018, 09:29 PM   #40
So the bottom line is I dream The Impossible Dream or is there an answer.
07-08-2018, 12:16 AM   #41
mcgregni's Avatar
Tell us what sort of flash photography you want to do, and the sort of situations you will be using flash for. Only then can specific things be suggested.
07-08-2018, 05:36 AM   #42
Class A's Avatar
the RF60(x) has certain power and performance similarities to the Pentax model, but whereas the AF-540FGZII might be considered the ideal 'rich mans' automatic flash for on-camera use, the Cactus simply cannot be used in the same way at all. It will only offer TTL automated flash exposures when controlled by the V6II transmitter with the specific firmware needed, and this means it is most suited to an off-camera role.
Wow, so you pay less to get better pictures?!
Seriously, personally, I wouldn't pay extra just to be able to pop a flash on to the camera.
  1. Off-camera lighting will typically result in much better images.
  2. Even when using bounce-flash, off-camera usage can be beneficial for improved power or consistency (when moving with the camera).
  3. If it has to be on-camera lighting for some reason, I'd recommend to get a flash bracket. I find regular camera-flash combinations unpleasant to handle (the considerable weight of the flash exerts quite some force when using the camera in portrait mode, for instance. A good flash bracket provides further purchase on the overall quite heavy camera-flash combination and fancy flash brackets even support quick re-orientation of the flash. A V6II with an RF60X on a flash bracket beats a regular on-camera P-TTL flash, AFAIC.
07-08-2018, 10:13 AM   #43
mcgregni's Avatar
Well, we're waiting for BruceBanner to prove me wrong on the bracket vs on-camera flash argument! Personally, looking at the various contraptions, ball heads and metal work being shown in Bruce's thread, I think I'll be sticking with my Pentax flash straight on the hotshoe ....
Bounced and flagged flash from on top of the camera can be every bit as directional as off camera. Like with my butterfly face photo, when there is no space for off camera gear, or you just don't have it with you, then on camera flash comes to the rescue.
Of course, indoors, we all want to avoid the poor results and shadows from direct flash, so bounced and flagged is the way to go.
07-09-2018, 11:44 AM   #44
Just want to shoot family and friends, some landscapes and very few portraits (head and small groups)
07-10-2018, 08:48 AM   #45
Class A's Avatar
Just want to shoot family and friends ... and very few portraits (head and small groups)
Indoors?
Outdoors?
Candid shots with people moving about erratically or more controlled situations (e.g., where you can keep the background framing and the subject<->flash distance relatively constant)?
Regarding landscapes, you'll probably find it difficult to achieve anything useful with speedlights due to lack of power unless you are considering low-light scenarios and multiple speedlights and even then it would be an interesting endeavour.
flash, lighting, pentax, photo studio, strobist
Abstract how to control morning burn? inder81jeet Photo Critique 9 07-05-2017 10:54 PM
drill baby drill or burn baby burn.. jeffkrol General Talk 25 07-02-2010 02:16 PM
Anyone with money to burn: A* 135/1.8... amateur6 Pentax SLR Lens Discussion 7 11-29-2009 08:09 PM
Money I don't have on things I don't need daacon Pentax SLR Lens Discussion 5 12-13-2007 10:04 PM
All times are GMT -7. The time now is 04:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
