So here's my StrobeScoop constructed from 5mm craft-foam and satin-sheen nylon. The aim was to get a broad diffusion from direct flash. I'm satisfied with the results, although as it's designed to scoop and push all light forward - (ie: no ceiling-bounce) - it needs to be used in conjunction with secondary light to lighten the shadows. The diffusion is very nice and gives a good sense of depth even when the subject is very close to the background surface.
It's a handy addition to close-up/macro shots in the studio when diffused side-lighting is needed but there isn't enough room for reflector umbrellas.
The whole thing is made from a single piece of foam. The forward-tilt is self-supporting and the whole unit is very sturdy. As usual, the unit fastens to the flashhead by velcro.
This was the precursor to my
CatchlightBounce (which, by the way, was used to take the profile shots of the StrobeScoop, seen here), and I was originally attempting to design something for on-location gigs but, as you can see, by the time I got to this prototype, it had evolved to a size that would be annoying and cumbersome in crowds and cramped spaces.
