07-15-2018, 06:39 AM   #1
Af360fgzII HSS testing help
During a football (Europe)/ Soccer (American) shoot recently I had one of my 3 360s act up. Off course I was paying more attention to the shoot than the flash so I did not have time to diagnose at the time. Now at home I am trying to isolate which flash it is and the issues. What I need help with is.
1. Does anyone have a lab type test for HSS to issolate
2. Battery or flash issues
During the shoot I had one flash give me 1st erratic results then 2nd consume batteries.
This shoot was a testimony to me that you always need back up equipment which I did and the shoot went well despite the one flash going down.
Thanks
Todd
07-16-2018, 02:54 PM   #2
Mikesul's Avatar
QuoteOriginally posted by 77tbholmes Quote
Thanks
Todd
I am having trouble understanding your problem. Are you saying that one of your flashes had erratic results and then drained the batteries? Low batteries could have been the cause of erratic results.
I am not sure if you are saying that you cannot determine which flash had problem. I must have misunderstood that.
07-17-2018, 05:01 AM   #3
The problem is:
1. Confirming which flash it is
2. Confirming battery under load problem
3. Confirming if flash problem
I am leaning towards it being a battery issue but on the day of the shoot I put 2 sets of freshly charged batteries in one flash and it responded the same at the time. Now I could just simply use the 3 off of 1 camera and lens against a model but I was hoping to find a more accurate method.
07-17-2018, 11:54 AM   #4
mcgregni's Avatar
I'm not able to understand you, sorry. I think you just have to try your flash a few times as you would plan to use it in a real situation ... That's the best test, and only you can do it.
07-17-2018, 06:52 PM   #5
Mikesul's Avatar
The problem is:
You have told us what you want to find out but I do not think you have explained exactly what happened to make you think there is a problem.
07-18-2018, 05:17 AM   #6
I think I located the problem. It appears that one of my AA chargers although indicating a full charge is not producing fully charged batteries.
07-18-2018, 05:17 AM   #7
af360 fgz ii, af360fgzii hss, flash, hss, hss flash question, issues, lighting, photo studio, shoot, strobist, time
Best way to fire my AF360FGZII removed from the K-3II hot shoe blb511 Troubleshooting and Beginner Help 4 04-24-2017 05:07 PM
Starting to test Godox HSS with Cactus V6ii, HSS works in AV mode? jake14mw Flashes, Lighting, and Studio 6 04-13-2017 07:30 AM
For Sale - Sold: Pentax Flash, AF360FGZII, Weather Resistant, Leaked Battery = Damaged Newtophotos Sold Items 7 01-12-2017 01:01 PM
Radio trigger for HSS I don't care about P-TTL just HSS. PTTL not neccesary or wanted MD Optofonik Pentax Camera and Field Accessories 11 05-04-2013 03:59 AM
All times are GMT -7. The time now is 11:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
