08-14-2018, 09:25 AM   #16
mcgregni's Avatar
Glad to have helped! There's some supposition involved regarding the flash metering sophistications, as there is almost no technical data available to us, but other forum members might have further knowledge ......
08-18-2018, 07:35 AM   #17
Linux compatibility update
QuoteOriginally posted by kaseki Quote
W.r..t. subject (b), attempts to install the Cactus firmware tool into a Crossover Linux Win 7 bottle have not been successful. .NET 4 is needed, and the installer hangs trying to download it.
Later....
.NET 4 requires a Linux package that the Cactus installer wouldn't know about. So it was necessary to install .NET 4 individually. I can get the Cactus installer to start, but it doesn't see a device to load the firmware to (because I don't have one, at a minimum) so it is waiting for the next step.
In other words, it is possible that the V6/V6II/RF60/etc. can be supported by at least one Linux flavor, in my case Mint 64-bit MATE (and probably any Linux that Crossover supports).
To the best of my knowledge the V6II does not emulate a mass storage device.
I hope you can get your Linux solution to work.
Having obtained a V6II and RF60X, I have delved a bit further into Linux compatibility.
  • First, the Cactus Firmware Updater V3.07 can be installed into older and newer builds of Crossover Linux running on Linux Mint using any of Win XP, 7, and 10 "bottles."
  • Second, Linux Mint itself can communicate with the V6II when it is in its firmware update mode. The V6II uses the Human Interface Device 1.11 spec USB compatibility mode. Linux can interrogate this device using such commands as "lsusb -v" and "udevadm (...)" for more V6II details than one might want.
  • Third, the Firmware Updater running under Crossover cannot (so far) see the interface with the USB device. This is likely due to the just-discovered-by-me position of Crossover to not support serial devices. To date their site suggestions for getting a connection haven't been successful. (Essentially, the V6II designated "/dev/hidraw3" by Linux Mint needs to be linked to "/dosdevices" in the Crossover windows part, but variously named links haven't been detected. I have asked Cactus by email what device name they are expecting to see.
Frankly, given the close parallelism between modern Mac OSes and Linux OSes, as well as the heavy Linux usage in China, I am surprised that a Linux based Cactus Firmware Updater is not available.
analog, bodies, cactus, camera, communication, film, firmware, flash, flashes, lighting, linux, memory, operations, p-ttl, photo studio, slave, software, solution, strobist, subject, ttl, v6, variant, version, windows
Cactus set to Relase New Firmware the Cactus V6ii for Pentax fwbigd Flashes, Lighting, and Studio 12 11-07-2017 05:31 AM
Pentax K30 (Cactus V6ii) + Metz 52 AF-1 (Cactus V6ii) = HSS only ( 1/180+) AldaCZ Flashes, Lighting, and Studio 11 05-21-2017 11:41 PM
HSS With Pentax K-1+Cactus V6ii and Godox 360 fwbigd Pentax K-1 19 03-10-2017 08:55 AM
Pentax K1 and Cactus V6II and Cactus RF60 on location portrait shoot gsande2016 Post Your Photos! 3 11-09-2016 07:01 PM
Cactus RF60 and Cactus V6II with Pentax K1 gsande2016 Flashes, Lighting, and Studio 3 09-16-2016 02:24 PM
All times are GMT -7. The time now is 07:24 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
