Originally posted by sureshgvv Hello all,
Success - I was able to get the flash to trigger beyond the sync speed.
Issue - when the flash was at full power, camera recognizes the output from the flash however at any other power, the camera is not recognizing the flash output.
Hello, just to clarify.
When you say that your flash triggers beyond sync speed, you mean that YOU see that the flash fires, so you think the flash is firing & synching in HSS mode.
When you say that the camera only sees the flash at fulll power, you mean that from 1/200 to 1/8000, you see that the flash fires, but you only see the flash output on your picture when the flash is at full power, maybe at 1/1-1/3EV you can see a bit of ligh at the bottom of the frame...
Is it correct?
If so, this is my guess:
Your camera-flash is not synching HSS at all, you are just synching in power sync mode on the cactus V6II and no matter if you set the AD200 on HSS mode, this mode is not being 'activated' by your trigger. When your flash fires at full power it generates a pulse for long enough so the camera can 'sync', and part of the light reaches the sensor. Sorry, there are really better explanations of power/hyper sync over there
. If you have time, you can read my thread 'AD200 HSS frustration', I had the same problem or very similar to yours, but found a solution.
As far as I know, and I tested a lot of Godox flashes and triggers, only the XproC (maybe the XproN too) is able to use the V6 II's normal sync mode properly, is recognised by the V6 II as a real Canon device and sets the AD200 in HSS mode automatically.
For other triggers and flashes that support the Godox X protocol, my solution was to put a configuration similar to:
CACTUS - pentax camera & manual flash, power sync mode
AD200 - disable wireless mode, put in HSS mode manually and put an extra XT16 receiver on the USB port.
I know, it's a sad solution, and I hope I was wrong. Maybe with K1 & X1T-N/Godox R2 you could put it to work without the extra receiver. I could't test such combination. Please, let us know.
Regards.
