Originally posted by Photogoof I don't have a studio setup, or even a ring flash. I shoot primarily outdoors. I'm wondering what the best approach is for using my flash on-camera indoors, especially for large areas, with or without high ceilings.
Different people will have different opinions, Photogoof, such as Terry Richardson.
My own belief is that the built in flash is best used outdoors in daytime as fill and catchlight only, forget about almost all other user cases. The K-1 doesn't even have one.
A real flash in the hotshoe can be used indoors either bounced or with a Fong/Flashbender/Magmod etc style diffuser if ceilings are high or dark like in a nightclub.
Btw, a 'studio' is wherever you want it to be.
The second shot is outdoors, in daytime. Under a bridge, against the wall.
It is a ring diffuser over a flash on camera just like yours, so you can do it too.
The point is to make the light bigger.
Bouncing a flash means using the light from a whole wall instead of a piece of plastic just a few centimetres in size.
