08-10-2020, 02:24 AM - 1 Like   #286
QuoteOriginally posted by Pablo Villegas Quote
Donít have the Pentax trigger yet, and I ordered a X2T-P not the Xpro-P. But Iíll try it when it gets here. Yeah, I do believe you can manually force HSS on the 360ii, but have not actually tried it.
Great. I have tested the setup ('downgrading' my AD200 + XT16 receiver) with the X2T-P and it works too. Unfortunately, the X2T-P have a problem with legacy flashes, because it can't enable or disable legacy flashes, but still can fire, change power or use HSS. Notice that a 'downgraded flash' becomes a legacy flash.
Regards.
08-10-2020, 03:45 AM - 1 Like   #287
I decided to buy another Ad200 and the double head adapter, that way I can have one more stop of light if I need it.
The AD-B2 is a nice device. Time ago I had the same idea: I had one AD200 unit and bought the AD-B2 to test it. So my idea was to buy another AD200 unit later. But then I found a great offer for a new AD400 so I bought it and forget abot the second AD200. I still have the AD-B2, so I can make a test for you, if needed.
Regards.
08-11-2020, 10:14 AM - 3 Likes   #288
QuoteOriginally posted by morenjavi Quote
Regards.
Well, my X2T-P arrived like an hour ago, and i just tested it. it works out of the gate with the AD360ii in HSS! I dont know why people reported it as not working, I did absolutely nothing special, just turned both on and chose the trigger sync as HSS, thatís it! no need to do anything else on the flash. You can change power as well.
One image is at 1/400 and the other one is at 1/250 on a Pentax 645D that sync tops at 1/125. The Godox 360ii changes from regular to HSS when you go pass 1/125 of a second in camera, automatically.
You can check the settings in Flickr
https://flic.kr/p/2jvgK4S
https://flic.kr/p/2jvjpUg
PENTAX 645D  Photo
PENTAX 645D  Photo
08-11-2020, 02:07 PM - 1 Like   #289
Great. I suposse that people was referring to the lack of support for Pentax TTL. But its obvious that HSS is supported. Congratulations!
08-11-2020, 02:39 PM   #290
Godox own page say it doesnít work. And every reviewer has said the same. Even here it was the popular knowledge that it didnít worked.
Thanks for all your help.
Saludos! Y gracias de nuevo!
08-12-2020, 01:16 AM - 1 Like   #291
Well, you have been able to test it, check that it works and publish your results here. Great.
°De nada!
09-10-2020, 02:51 PM   #292
Riggomatic's Avatar
Finally...after a few minutes here, few minutes there over several weeks, I was able to get the HSS working on the X2T-P on my K-5, and a V860ii-C.
Not sure what I'm going to take pictures of, but just knowing I have the capability is my win for the day.
Just thought I'd share that.
09-10-2020, 04:51 PM   #293
Aaron28's Avatar
QuoteOriginally posted by Riggomatic Quote
that's always a win! good deal........no doubt you could several things that could use some fill flash !
adorama, bug, cable, camera, canon, control, firmware, fix, flash, gear, godox, hss, lighting, neewer, pentax, photo studio, power, shutter, strobist, support, system, ttl, ttl wireless flash, unit, users, xpro-p, xpro-p ttl
Pentax K1, Godox AD200, Godox XPRO and Cactus V6 II: HSS Setting Instructions howieb101 Flashes, Lighting, and Studio 28 10-24-2018 02:23 PM
Acon R930 P-TTL radio trigger and 2 flash setup, what flash do i need. GraySaint Flashes, Lighting, and Studio 30 11-24-2016 11:19 AM
Aokatec AK-TTL Radio Wireless TTL Flash Trigger for Nikon Canon Pentax Sony callmeraymon Flashes, Lighting, and Studio 28 08-25-2012 01:24 PM
All times are GMT -7. The time now is 08:46 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
