Originally posted by CarlJF The MZ-S supported both the legacy TTL and, at the time, newer P-TTL modes. The 360FGZ and 540FGZ also supported both modes. So, it's expected for the MZ-S to work with the older flahses (the camera will simply work in legacy TTL mode) or for the 360FGZ and 540FGZ to work with older camera as the flashes will set themeselves in legacy P-TTL mode.
The *istDS supports TTL as well as pTTL
BUT !!
If the flash also supports both modes, the camera cannot be forced to use TTL.
Unfortunately, this is also true if the flash can be set manually to use either TTL or pTTL, as it seems the camera can detect (at least with Metz flashes) that the flash is capable of pTTL. Then the camera will not send the signal to stop the flash, and the flash will ignore the commands for pTTL from the camera. The result is chaotic behaviour.
Change of protocol by Pentax:
There have been several. I own 2 flashes (1 Soligor, 1 Cullmann), which work alright (pTTL) with the *istDS and the K200D, but turn into a stroboscope with the K-5 (and set the top display illumination blinking).
