It was great to see Cactus release the firmware update for the older V6 trigger, that makes it compatible with the newer V6II when the V6II is running the "XTTL" firmware version.
Now its possible to run the XTTL frimware on the V6II for use with any compatible P-TTL flashes, but also to add a V6 (or more) into the mix if you want to switch to manual mode. This is with a single press on the group buttons, so very convenient. So my V6 has come back into use attached to the AF-540FGZII, with remote manual power control.
I had a chance to put 3 lights into practice as our eldest daughter started High School, a big event for us, so of course the softbox, umbrella and hair light were all set up ready to go when she got back!
The main light is a softbox just outside the left frame edge, angled down, and the fill is an umbrella slightly behind my right shoulder. The hair light is a bare flash (with max zoom) behind the subjects left shoulder, a few feet back.
I've been quite pleased with the softness of light I've been able to get from a fairly small softbox (25x25 inches) and a simgle flash gun. This type of collapsible box is really designed for bare bulb type lights, as the light should bounce around inside and reflect off all the walls. A hotshoe flash points directly at the subject and a lot of its light will not directly hit the walls, therefore it tends to create a hotspot on the face.
I am trying to avoid this with a Gary Fong LightSphere dome on the flash head which throws the light all around and I find creates a nicer effect ….
