09-21-2018, 11:56 AM   #1
Which flash is better for my K-1
So I don't do a lot of flash shooting, but I do occasionally find myself wishing I had a flash for this camera. I know the 540 FGZ II is overkill for what I need, not to mention over my budget. I'd like to keep it at $250 or less.
I'm considering a used Flash Either the Pentax Auto Strobe AF 540FGZ (ver 1) or the AF360FGZII. Are there others I should consider?
I'd use it mostly for Fill flash or in darker indoor settings, and some Macro shots. I'd like to be able to use HSS and P-TTL/TTL modes.
Thanks for any advice on this.
09-21-2018, 12:03 PM   #2
Check out the AF201. It might be too small for what you want, but for general use, it replaces a flip-up flash, is very compact, and has four modes (auto and manual). There are reviews of it here: PENTAX AF 201FG reviews - Pentax Camera Accessory Review Database
I have the AF540 and the AF201 and find myself using the latter more often because of its size and I can drop it in a pocket when not using it if I don't want it on the camera. It has a flip-out diffuser for use with wide lenses and takes 2 AAA cells which deliver pretty good lifetimes considering.
09-21-2018, 12:30 PM   #3
For your requirements my advice is the Shanny SN600FGZ.
Best regards,
09-21-2018, 02:08 PM   #4
Either of the Pentax AF360FGZs are good value for money and fall in that range(ver 1 or two). I have one of each and they get used more than the AF540FGZ I have.
09-21-2018, 02:10 PM   #5
Forget Pentax units, They are way too expensive.. My advice would be the Shanny SN600FGZ If just wanting a single on camera flash system. Powerful, HSS P-TTL.
09-21-2018, 02:20 PM   #6
Thanks All, I just ordered the Shanny from Amazon.
1 Day Ago   #7
Review
What did you think of your purchase ? As a newcomer to flash it would be interesting to others in the same position..?
17 Hours Ago   #8
QuoteOriginally posted by stub Quote
I've used it a couple of times around the house, but haven't had a need yet. But when I do I have it on hand.
flash, lighting, photo studio, strobist
Which lens is better for my MZ-S OldChE Pentax SLR Lens Discussion 12 03-31-2018 08:48 PM
Better camera (K-3) needs better glass? mgvh Pentax SLR Lens Discussion 33 12-10-2016 01:49 AM
DSLR's just keep getting better and better whitedogone Pentax DSLR Discussion 13 06-24-2008 09:05 AM
Which lighting works better? My new toy JMS Photo Critique 6 05-07-2008 01:57 PM
Which model better fits my needs? VE2CJW Pentax DSLR Discussion 2 11-05-2006 08:49 PM
All times are GMT -7. The time now is 10:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
