Originally posted by mcgregni I’ve just been testing ready for a shoot, and I wanted to use my old M series 75-150mm. It hasn’t been mentioned in this thread what lens was being used, but it seems to be important, because I can report that I could not use my M series lens .....I have had to return to using an autofocus zoom to get consistent and controllable results from the Cactus flash gear .....and that is in M flash mode.
I’ve seen this before, but thought it had been resolved with firmware.....apparently not. I am using PEN.A.003 on the V6II, with an RF60 flash (also on the XTTL firmware). In Manual flash mode with the M type lens I get some non-fires (fairly frequently) and also no control over flash power, usually every 3rd to 4th time, then it takes 2 tries to get the flash power to respond to inputs on the V6II.
All of these issues are resolved with an autofocus lens, and I get 100% reliable operation. It was not said what lens was being used here in this thread, but it’s something that should be specified in relation to XTTL firmware and troubleshooting.
Hi mcgregni, welcome to the party
On my day (and in the video) I was using FA77 and HD DA 35 Macro, so yeah, this was still occurring with AF lenses (I no longer have my beloved Samyang 85
I agree with you tho, using MF glass, the results are even more bizarre. TTL or M some shots would just go crazy and be a full power, then the next shot it would calm down and give a more accurate exposure. Odd.
I did a test shot yesterday, everything went fine except I did have to fire off one TTL shot first at the beginning of the session to then get M mode to work.
