Rather than start a new thread I thought I'd continue this one with a slight deviation.
I started a new thread hehe;
Small Flash Suggestions - PentaxForums.com
I have now come to realise that with the Godox V860ii, the tripod screw hole that it uses is actually on the
plastic feet that attach into the hotshoe of the flash (although the tripod screw hole is actually at least metal). This makes it a difficult 'run and gun' flash. I'm not a fan of using a heavy flash (which this is said to be) with additional weight added via modifiers (magmod sphere as well as the maggrip), that stress is now on the hotshoe of the flash and onto the plastic feet and then docking into something like a flash bracket... I sincerely doubt I'll be using a swivel ball head on my flash bracket as before, it would just start to be way too much of a ridiculous wobbly 'tower'.
So, the V860ii is starting to look a lot like a OCF only, and not something that would easily be applied in a running and gunning scenario. So I'm turning my attention to perhaps another second flash alternative, this time in mind with purely 'running and gunning' application.
Now thus far I have owned a FGZ 540II (and sold it) as well as a Metz 44-AF2 (sold that too). Both of those flashes were heavy and required to be in the hotshoe of the K-1 which I never liked, or use a cable and have perhaps in hand or in a flash bracket, but really because they lacked the inbuilt wireless receiver tech (and I was never overly fond of the idea of using a Cactus V6ii as a reciever, ie i want to avoid hotshoe and stacking as much as possible) I sold them.
But now I am curious to explore other
small flashes, perhaps super light ones, even fairly under powered ones that might still really suit that 'running and gunning' scenario. These flashes might not even support TTL or HSS, something that can either sit in my flash bracket (as pictured above) or indeed the hotshoe of the K-1 and simply take a magsphere to provide a better softer shot than using bare.
The kinda scenario I see myself using this flash would be evening receptions at weddings, or basically indoor, for proper outdoor shots I would likely use OCF and the V860ii (or even skip this flash and go straight to a AD200).
Now I am the first to admit I haven't even looked into all the different kinda flashes that might tick those box of requirements, but can any of you recommend or chime in with any experience of some of the smaller flashes? For example ones like these;
Pentax AF201FG Flash 30458 B&H Photo Video Metz mecablitz 26 AF-2 Flash for Pentax Cameras MZ 26337PEN B&H
The only thing I would need to check is;
a) that the Maggrip can fit around the flash and stay tight (typically I think that will work, even for quite small flash heads)
b) that whatever flash I get, could I use a cable to run from the K-1 Hotshoe, to the flash bracket (and therefore flash), just so I might not have to have it on the K-1 if I am concerned over the K-1 hotshoe taking too much weight strain (as I will be 99% of the time using a bagbounce or magsphere with it. I have seen pictures of K-1's hotshoe 'peeling' away from teh camera body :'( I want to void this happening at all costs).
