***If you can't be bothered with the back story just skip to the *section below
So... after much deliberation I am thinking of skipping on the whole Godox V860ii speedlight units and heading straight for the AD200 (with the XproP trigger) along with a small Pentax (or Metz... or whatever) flash for the 'running and gunning' side of things.
This decision comes from the fact that once the XproP trigger is on the K-1, there is
no other way to mount the V680ii flash to a flash bracket other than it's own hot shoe or using the plastic feet it comes with and using the metal tripod thread on that (and then mounting the flash into it's feet via the hotshoe). Urgh...
This is my current flash bracket, and I have attached the cactus feet onto it to try and imitate what the V680ii would be like;
Now imagine that on top of my ballhead swivel system, with a magboob (or magbounce) on top, or even if I did away with the ballhead that currently exists on the custom bracket and just mounted the flash onto the bracket via a hotshoe (or use the feet plate), it's still not ideal (I lose one of the major benefits of the flash bracket which is portrait mode shooting like this
(even this shot like this is not ideal, this is by no way a great way to shoot lol).
So yeah... I've been trying to think about the situations I shoot in where I am 'running and gunning' and really 9/10 times it's indoors, an evening reception or even my own home, with a magsphere on top of the flash to provide a nice omni direction light to assist with fill. HSS I don't need, because in those situations I will get something proper out like the AD200.
So then, I think I'll be doing away with the flash bracket and instead utilise the K-1 hotshoe and actually.... <gasp> put a flash in it!
Here's where things get interesting.
I have owned a FGX 540II and a Metz 44 AF-2, and I sold them both. No regrets here, they didn't really tick all my boxes, and when I decided to start to go ocf they weren't very useful and the funds I made on the sales helped fund my cactus v6ii and RF60x (which I'll be selling to fund a XproP and AD200).
The main issue with both of these flashes were size and weight, that in combination with a magboob or magbounce makes them really top heavy, with no lock for the orientation of the flash it was just a constant frustration. Factor in that weight and wobble on the hotshoe of the K-1 I was very concerned about the health of the K-1 hotshoe keeping up with this system.
But they both supported HSS, and that was handy, but really I never used HSS that much, and if I were it was more in the a 'modelling session' where there is an expected degree of setting up etc, it wasn't really 'candid' HSS.
And so this brings me to the idea of settling with a small 'indoor candid' flash, where HSS is probably not required. TTL could be handy however, but Manual power is definitely a must and hopefully one that allows for a good degree of increment changes. I don't know the terminology for this, but something similar to the cactus rf60x increments/steps (just not as powerful).
***So I'll list the things that I think I would appreciate in a small flash unit, I have no idea if such a product exists so perhaps I have to compromise somewhere.
1) Small & Light, probably only taking a couple of AA/AAA, not the kind of weight of 4 AA's etc.
2) TTL as well as Manual Mode (and a good degree of control over the power output)
3) The head MUST move, at least tilt so that I can have a magmod boob on it and decide if I want to fire it straight up to the ceiling or tilt down and fire directly ahead.
4) Rotation of the head is optional, one direction (to the right) might even be handy if I wanted to do a portrait shot (and fire the magboob directly up to the ceiling). I won't be doing much if any bounce off wall flash stuff, just simply up, ahead directly, and possibly it might be nice to pan the camera to portrait mode and tilt the head up towards the ceiling (but I can live without this I think).
5)
Lock, or at least extremely stiff head, with a maggrip and magboob attached on a small head (even the large heads) when the boob is pointing directly up to the ceiling it would dip down
all the time unless you swiveled the head right around so the hinge faced you, this would lesson that occurrence, but really a lock would be most ideal.
6) Optically triggered, or Slave mode... or whatever. What I mean is, I would like the ability of the XproP or the AD200 to set the flash off also, if that is at all possible, this would be handy in a studio setting, using AD200 as key light and the smaller flash as fill or rim light etc.
7) Can accept the Maggrip so that it can take a Magboob
There is no budget set on this, buying two is even a possibility (if they can fire each other off).
The failure of the V860ii being able to easily dock with my flash bracket has just made me question the whole nature of my 'running and gunning' need, do I need HSS? do I need massive power? Am I using it to light up a massive room, or just to help as a fill light and increase IQ. The latter is the answer.
So... does such a thingy exist?
