Originally posted by MichelMarin Ok. I am trying to get this straight. My old AD360 works with a 433 MHZ receiver. I bought one 2.4 g some day and tried to use it on my AD360 and nothing happened. Hey! Now I am realizing that I used a 433MHHZ trigger to do my testing! Lol may be that was the problem to trigger the flash that time. So, u are positive about both receivers can trigger my ad360? That would be so nice!!! Because then i can buy a X PRO and HSS my lighting!
Hello, sorry for my first answer, but I though you were referring to the AD360 Mk I.
Inkista is right about the AD360 MkII.
If you are asking about triggering the old AD360, I have one, and I can trigger with old or new triggers/receivers, you need of course use trigger and receivers with the same technology, that is 433Mhz or 2.4GHz, but they will work.
About getting HSS with the old AD360 and the XProP, you should be able to get HSS with a XTR16 receiver. I was able to get HSS with the XProC + Cactus stacking (before the XproP was released). Now, there are forum members that got HSS with a XproP + V850, that needs the XTR16 as you should put on the AD360. For me, it's exactly the same case: if you can sync HSS with the V850, you'll success with the AD360 too.
About the AD360II, as inkista said, it does not support Pentax TTL, but you should be able to get HSS. People have got HSS with the AD200 (and others flashes) that still doesn't support Pentax TTL, I see no reason to not get HSS with the AD360II, that supports the same Godox X protocol.
Regards.
