Originally posted by Digitalis That ring-light modifier looks like a good place to start - I'd expect you would lose a considerable amount of flash power when using it though.
Here is a quick portrait of one of my assistants purely lit with the Pentax AF160FC ringflash:
Pentax K-1 - SMCP-FA77mm f/1.8 Limited - ISO 100 1/200th @ f/5.6 AF160FC Ringflash at 1/8th power.
It can be problematic lighting faces of models that are wearing glasses* . The lenses can often cast hotspots,reflections, and the frames themselves can create unattractive, distracting shadows upon the subjects face - the use of ringflash allowed me to deftly side-step this issue.
* Reflective sunglasses are the worst.
Same, I was thinking the 360II should still provide enough grunt to punch through however. It might get problematic if using gels as well tho...
From what I have seen of that roundflash softbox tho, is that if you use 31-35mm lenses then the shots up close give that unique ring catchlight, whereas taking the shot further back akin to your assistant pic with the FA77 you get a less pronounced ring, almost just a single dot. So the lenses and closeness to the subject all changes and impacts the ring, for those that aren't a fan of it I would argue it becomes less of an issue if you simply increase your distance a bit. The only question for me is if using the FA77 and HSS stuff, will the 360II punch through enough when the subject is 3-4m back etc... Guess I'll find out.
With other lenses like 35's and 50's I don't think power from that flash will be such an issue.
Nice shot of your assistant by the way, I want to work for you
The thing I most like about the ring flash (or roundflash softbox) is the way it handles the behind shadows cast from the shot, they are definitely interesting 'hidden' shadows, almost like a 'dark halo' which in the right setting and scenario you're aiming for (grungy/edgy etc) I think it looks pretty swell!
I'm curious as well to shooting at carnival type events with the roundflash, I recall seeing this guy shoot Sammy here and he was rocking this combo;
And I've thought about going down that route also, even possibly with the cactus RF60x so holding the roundflash softbox off to the side as well. The possibilities are endless, guess it's all learning curve stuff.
