Show Printable Version 4 Likes Search this Thread
10-14-2018, 11:54 AM   #16
UncleVanya's Avatar
QuoteOriginally posted by mcgregni Quote
Yes, but with the 105mm flash setting we could light up something a lot further away, something that might look very small through that 28mm lens.
I suppose I was trying to avoid us giving the impression to the OP that GN was somehow related to the lens on the camera, as it isn't. GN is affected by changes to flash zoom settings, as the longer settings throw light' further along a narrower pathway. Guide number can be calculated even without any lens.
On Pentax flashes the zoom is automatic in p-TTL can you disable it? I know you can override when you are on manual mode, but I'm away from my gear.
10-14-2018, 12:15 PM   #17
photoptimist's Avatar
If worth noting that the guide number is a non-linear value -- power goes with the square of the guide number. Based on the numbers people have found, the Cactus RF60x puts out double the light (1 stop) of the Metz M400 flash. And the numbers people have found seem to imply that HSS for 1/500 shutter speed is maybe 1/8 the light of a normal flash (3 stops).
Thus, you can simulate the Metz M400 flash HSS @ 1/500 second shutter speed with the Cactus RF60x fired normally at 1/16th power. And if you want to simulate rapid cycling see if the Cactus RF60x @ 1/64 is enough light.
Overall, HSS requires a lot of power to get a fast shutter speed.
10-14-2018, 12:35 PM   #18
UncleVanya's Avatar
This is why some methods rely on using a lot of ganged flashguns to get enough light.
10-14-2018, 01:10 PM   #19
mcgregni's Avatar
Regarding the question about Pentax flashes auto zooming in P-TTL mode .... Yes, the Manual flash zoom button overrides things, allowing a manual setting to be fixed even when focal lengths are changing in P-TTL mode.
11-12-2018, 12:07 PM   #21
angerdan's Avatar
QuoteOriginally posted by BruceBanner Quote
How can I get an idea of what the M400 will be like, in terms of power output?
I mean it's a smaller more compact flash (which is great for the purposes I want), however that should mean it's quite a bit weaker than the RF60x I'm imagining... but in real terms by how much?
Like the Metz M400 does HSS, but is it pretty bad at it?
Why not go for the AF 360 FGZ II ?
11-12-2018, 12:42 PM   #22
BruceBanner's Avatar
QuoteOriginally posted by angerdan Quote
I did in the end, as well as nabbing a AF201. I was just curious to see the difference of power vs weight/bulk of the M400 vs 360II but now that I own the 360II I am very happy, it's actually way more compact and lighter than the 540II which I did not like at all.
11-12-2018, 01:28 PM   #23
UncleVanya's Avatar
I have the version 1 of the 540 and 360 and agree - the 360 is quite a bit smaller.
11-12-2018, 01:35 PM   #24
Yeah I really felt the weight and stress of the 540II on the K-1 (let alone KP!). I hate hotshoes in general and have seen images of the Hotshoe plate come away from the K-1! It's a weakness in design imo, so for longevity the lighter and smaller the thingy you dock into it is prolly a good idea.
I'm just unsure how much power I am losing however from using a 360ii vs 540ii. I do shoot through my ring flash thingy for example.
11-12-2018, 01:43 PM - 1 Like   #25
UncleVanya's Avatar
Understanding Camera Flash Guide Numbers, plus GN Calculator
The AF540 is guide number 54, the AF360 is guide number 36. These assume ISO 100 and 85mm zoom. The AF540 at 1/2 power is about guide number 38. This means the 360 is just under half the power.
This should also help: Pentax AF360FGZ II Flash Review - Specifications | PentaxForums.com Reviews
11-12-2018, 02:03 PM   #26
Thanks!
11-12-2018, 03:43 PM   #27
UncleVanya's Avatar
Thanks!
Happy to help.
flash, flash power, hss, lighting, m400, metz, output, photo studio, power, rf60x, strobist, terms
Does the D-FA 28-105mm on K-1 compare favorably against the DA* 16-50 on K-3? HarisF1 Pentax SLR Lens Discussion 7 11-03-2018 02:18 AM
NiSi V5 Pro compare Breakthrough compare... gatorguy Pentax Camera and Field Accessories 3 01-31-2018 12:19 PM
For Sale - Sold: two Pentax TR Power Pack-2 (external flash power) yurihuta Sold Items 2 03-13-2013 07:59 AM
How to power 540FGZ flash with Alienbees Vagabond mini II portable power? shadowbecomeswhite Flashes, Lighting, and Studio 2 07-25-2011 07:17 PM
another blow against nuclear power jeffkrol General Talk 234 05-03-2011 02:33 PM
All times are GMT -7. The time now is 08:56 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
