Originally posted by Class A For the Cactus flash, you'll need a Canon-compatible cable. Should be part of a PB960 deal or available as an accessory.
One of the "improvements" Pentax implemented for the FGZ II models is to eliminate the external power pack connector so you won't be able to externally power the Pentax flash.
The Cactus RF60X flashes have a separate battery pack (EP-1) available for a modest price (~$50). Batteries and charger are extra. This pack reportedly supplies 330 Vdc to the flash. This is the same voltage used by many other flashes, including the earlier Pentax AF-500FTZ flashes. The Cactus battery pack supplies this voltage via a cable with a Canon compatible plug.
For those owning older Quantum Turbo Batteries, the Canon CZ2 cable should work for the Cactus flashes. I will prove or disprove this in a couple of days and report. Used Quantum Turbo Battery assemblies, cables, charger modules, and replacement internal batteries where needed will be a higher cost than the Cactus EP-1 plus batteries, I expect, but if a QTB is already available, then obtaining a cable may be the lowest cost option. I will also try to determine whether the QTB recharge performance is comparable to the rated Cactus performance. The EP-1 performance is listed as 1.2s, so small differences will require a more complex measurement than I'm likely to have time for in the short term.
