Yeah I just had a trial just now with the V56 trying to recreate a similar look to the ring shot above, and that worked quite well. So I'll think I'll list that HD DA 35 Macro tonight.
but also
One last thing.
The V56 does seem to operate a little differently than my other non A settings K mount lenses, or in fact some other regular AF lenses. When in Av mode for example, changing the aperture gives direct 'optical preview' through the OVF or LV, simply sliding the optical preview switch across (at the shutter button) does nothing, it's basically 'on' all the time. Av mode (which is its intended mode for most uses) forces the shutter speed to 1/200, regardless of how much ambient light exists, so it means I need to be in Manual mode for flash work in order to control shutter speed. That would be fine except now the green button does nothing. I have no idea of exposure other than chimping so it seems. I can actually work with that except my aim might be to do approach a flash image shot something like this;
What you're seeing here is a aperture stack and blended image, 3 shots I believe to create a smooth bokeh whilst providing sharpness (without the velvet haze) where I wanted. In regular non flash mode this is a singe, because the V56 wants to be in Av mode you pretty much take the shot at one aperture, change aperture, shoot, change aperture and shoot again, then you do the harder work in post. I think this image is a combo of something like f1.6 (for the majority of what you see), f4 for some of the flower and f8 for the tip).
How then might I account for differences in ambient and flash power if wanted to do a similar strategy to above?
Let's take the ring shot for example, I might want to aim for a similar 3 blended stack but each shot must fire the flash at the same intensity as well as not deviating in ambient light. The idea might be to having some of the text extremely sharp (on the rings), then blending out to the f1.6 'flash haze'. I just tried it now with the V56 and flash, with the f1.6 haze and was quite a nice effect, it's definitely something I'd like to try properly, but I am not sure how to approach this.
So... for example I might decide I like what I see at f8, ISO 100, 1/8 and with 32+7 for flash power. Now I'd like to move to f4, but keeping the ambient light and flash power equal. Do I simply leave the flash power alone (leave at 32+7) and now just compensate with shutter speed?
Lensbaby Velvet 56 has the following selectable apertures;
f1.6
f2
f2.8
f4
f5.6
f8
f11
f16
when stopping down or up is there some kind of basic math I can do with shutter speed to keep things consistent?
