12-26-2018, 01:42 PM   #1
AD200 not displaying TCM properly
I have a new AD200 with the Pentax R2Pro trigger. I have the trigger set up for the AD200. When I shoot in TTL, I should get the equivalent manual reading when I push the TCM button. Instead I get 1/1 full power setting. My firmware is 2.1 on the AD200. There is a firmware upgrade of 2.2 but I am waiting for a USB to USB male cable to come in from Amazon. Will this upgrade solve my problem? Also, most of the time, the TTL exposure is about 3 stops too dark. I have to do a +3 on the setting. Will the upgrade fix this?
12-26-2018, 03:32 PM   #2
Glad to report that version 2.2 on the AD200 will incorporate the TCM function and will fix the severe underexposure problem in TTL. Hope this helps later Pentax users.
12-26-2018, 11:00 PM   #3
inkista's Avatar
Nice to hear. BTW, just to double-check, when you say you have the trigger set up for the AD200, do you mean you have the C.Fn TCM set to 200j, so that the Xpro-P knows an AD200 is the light being used for TCM?
12-26-2018, 11:20 PM   #4
That is correct Inka
ad200, firmware, flash, lighting, photo studio, setting, strobist, trigger, ttl, upgrade, usb
Pentax K1, Godox AD200, Godox XPRO and Cactus V6 II: HSS Setting Instructions howieb101 Flashes, Lighting, and Studio 28 10-24-2018 02:23 PM
HSS with Flashpoint Evolv AD200 and Godox R2 Trigger and Cactus v6 ii combo help sureshgvv Flashes, Lighting, and Studio 8 08-15-2018 02:50 AM
Anyone getting the Godox AD200? jake14mw Flashes, Lighting, and Studio 49 12-05-2017 11:33 AM
AD200 and TTL McRaw Flashes, Lighting, and Studio 6 11-30-2017 05:12 PM
Godox AD200 Flashes reivax Flashes, Lighting, and Studio 7 05-17-2017 03:24 AM
All times are GMT -7. The time now is 11:38 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
