Originally posted by Navmaxlp I used the RF60X as the master and put the TT350-P on the V6II. I could not get the flash to change power or zoom.
Which (exact) firmware versions are you using on the RF60X and the V6II?
If you can control/fire the RF60X from an on-camera V6II using P-TTL, you should be fine with respect to firmware versions.
Did you set the flash system on the V6II (in RX mode) to "Pentax"?
If not, did you leave it on "AUTO" and did the V6II recognise the TT350-P as a Pentax flash?
Note that the order of turning devices on matters.
Connect the TT350-P to the V6II, turn it on, make sure it is in "P-TTL" mode and only then turn on the V6II in "RX" mode.
If the auto detection of the V6II doesn't work with the TT350-P, try setting the "flash system" in the V6II to "Pentax".
If you still have no luck then you may also experiment with choosing one of the available flash profiles (available for the Pentax flash system).
Originally posted by Navmaxlp I'll assume the TT350 needs to be in manual mode when placed on the V6II which is in slave mode.
If you use the TT350-P in manual mode on the V6II, it won't support anything more than firing.
Remote power and zoom control are predicated on the TT350-P being in "P-TTL" mode, i.e., the mode in which it would successfully operate on a camera as a P-TTL flash supporting HSS.
