Originally posted by inkista And the problem here, I think is that "optical" and "P-TTL" both seem to have two meanings.
That's not true in my book.
There are two meanings (refinements) to "wireless" and "master" which are "optical"/"radio" for "wireless" and "optical master"/"radio master" for "master".
The term "optical" in this context always unequivocally references "transmission of triggering signals/information via light emission".
The term "P-TTL" refers to a flash protocol that supports features like automatic metering, HSS, second-curtain sync., etc.
A "P-TTL" flash is assumed to support the main features (if not all) of the "P-TTL" protocol.
As you wrote, such support can be delivered in the form of acting as an off-camera P-TTL flash or in the form of an on-camera P-TTL flash.
Many Godox lights (and the Cactus RF60X) support off-camera P-TTL but not on-camera P-TTL.
I understand you personally pretty much know all of this; it is just my attempt to contribute to a common understanding of terminology.
Originally posted by inkista No piece of gear in the Godox system can simultaneously be a slave and a master.
Technically I don't think that was relevant to the question you answered.
I don't regard a flash mounted to a radio receiver to be in "slave" mode.
Theoretically a radio receiver can be perceived as emulating a camera, so in theory a TT350-P on a radio receiver could be just in "optical master" mode (without having to be in a "slave" role as well). Of course, the situation is hypothetical because the TT350-P does not support an optical master role. Also, I'm emphasising the "theoretical" aspect of my point because most (all?) radio receivers do not perfectly emulate a camera.
Originally posted by inkista And it [TT600] can have its M power ratio controlled by an XPro, but it cannot be zoomed or do TTL from an XPro.
That's a bit surprising, AFAIC.
There should be no reason why zoom control or automatic metering couldn't be supported. The TT600's flash tube should support pre-flashes like any other such speedlight, no?
Potentially the TT600's MCU wouldn't be able to accommodate further firmware code, but I guess it is just a matter of model differentiation and not having to maintain the most comprehensive firmware for every flash model?
Finally, can the TT350-P operate as a radio master with respect to other Godox products?
BTW, thanks for all your input to this community. Much appreciated!
