Originally posted by Mike27596
I got a chance to buy cheap
used but in box ( really new).
maybe the reason it was cheap is that it is broken. Make sure the wide angle panel is not out. Zoom will not work with the panel out.
Also on the k-1 menu what do I set that to?
You dont
have to set anything on the K1. You can Change the white balance if you desire, and you can use the flash compensation controls. Set the camera to manual or Av and set the Flash to P-TTL. Start from there.
