Originally posted by Desperado Thank you for the answer,Their triggers support hss for pentax k5iis and ks2?
It should. The K-S2 is on the official compatibility list
on the Godox website. And
G and T on this forum said the K5iis worked in HSS/TTL with the AD200 and Xpro-P.
The AD600 Pro does TTL, HSS, and remote power control from an Xpro-P.
The AD600 / AD600M have similar power output and are less expensive; but the build isn't as nice, recycle is slower, and there's no color consistency mode, but the battery life is longer. The AD600 also does TTL/HSS/remote power; the AD600M does HSS/remote power.
They're all rated at 600 Ws. They're all li-on battery powered.
The Godox QT600II is an AC-powered strobe that also does HSS (but not TTL). Built-in radio receiver that allows for remote power control.
If you want smaller lights, there are the lower-power AD400 Pro, and AD200 (and upcoming AD200 Pro). The name gives the Ws power rating.
They all also have the Godox ALT/MASK feature, so if you have more than one unit, you can split the load between them. The 400 and 600 and QT600II let you use 3 alternating groups, the AD200 only does two. But this can effectively reduce recycle time to 1/3 or 1/2 by sharing the load among multiple lights.
