Originally posted by stevebrot Those three settings may not be doing what you think they do.
The exposure (shutter speed) is determined during the pre-flash. (Magic is used.)
On a more serious note, this sort of thing (automated balancing) is one of the strengths of P-TTL. You can override with a combination of EV comp and flash comp.
(...auto-ISO is evil...)
Originally posted by stevebrot That is because lenses without mount contacts get no automation when using flash. You get the X speed and your selected manual aperture. M mode will get you control over shutter speed. Even with contacts, those that are not AF get a reduced feature set.
Originally posted by stevebrot OK...there is some nuance. The camera will tend to err towards minimizing subject blur and will keep shutter speed high. It may even bump ISO to do so. (Remember, auto-ISO is evil.) You can at least partially overcome this by enabling slow sync. Another thing you can do is shoot in M mode and use the EV scale to determine initial ambient exposure manually.
Sorry, specifically I meant 'Auto ISO Parameters'. I change them depending on what the lowest shutter speed I think I can get away with for the task is acceptable before it bumps ISO up. So 'Slow' gives the slowest shutter speed, once you encounter this shutter speed only then will it increase ISO. So it's a way to control how the Auto ISO behaves. If you feel dropping to 1/60th in Av mode is too low, change it to 'Fast' where you might get 1/250th as your lowest shutter speed and it will adjust the ISO only once reaching that threshold.
The KP goes one step better than the K-1 and actually allows you to specify the exact shutter speed yourself, handy if 'Fast' is not fast enough, you can now have an Av mode whereby 1/1000 is the lowest shutter speed you'll encounter.
Of course this changes if you set your ISO range to say 100-3200, once you exceed 3200 it will then drop your shutter speeds below your 'wanted' lowest shutter speed.
I was curious that with the addition of adding flash if this logic is somewhat followed, so that perhaps a change of Fast, Slow or Normal might change where the shutter speed sits, but it doesn't appear to be doing that. Hence this thread, how does it decide on a shutter speed etc.
So for example, right now I have my K-1 with a DA 20-40 attached, I'm at 30mm and f3.5. The flash is off, my Auto ISO is set to Normal and my range 100-3200. With ISO in Auto mode I can see it's given me 1600 (for the location I am currently in, with a shutter speed of 1/50. So I know that 1/50 is the lowest this focal length wants to drop to before bumping ISO, I know this because Auto ISO is at 1600 (i.e. it's already raising it). If I toggle out of Auto ISO and now select 800 I get 1/25, I am basically overiding the Auto ISO Parameters.
What's kinda interesting is when we turn flash on (360II), it sets the shutter speed to 1/60 and puts me in Auto ISO mode, if I toggle out of Auto-ISO and set ISO to 100, 200, 400, 800, 1600 it stays at 1/60, only once I get to 3200 does it shift to 1/1000. I think this is what I was experiencing yesterday, it felt like for the room i was in whatever respectable ISO I selected the shutter speed did not budge (and I was at f3.5 and couldn't widen the aperture further). The idea of using 3200 ISO to get a little more shutter speed seemed ridiculous when flash was involved, indeed toggling off flash at this point (leaving ISO at 3200 meant my shutter speed stayed the same (1/100), so it made me kinda question what was the point of using flash at all, it didn't
help lower ISO in that situation at all.
I just thought it was interesting, what the shutter speed was doing under Av mode, even when fixing and changing ISO. For a 'Av' mode it seemed to stay pretty fixed throughout a largish range (ISO 100-1600, no waivering in shutter speed when flash was attached). I guess the P-TTL system will adjust the power of flash output between those ranges (ISO 100 would get the most severe flash output, ISO 1600 the least), the issue is if you have EV compensation (-1EV) and were wanting to mix ambient light with the flash then you really needed to set the ISO to Auto for this to occur, otherwise fixing ISO and having no drop in shutter speed throughout 100-1600 results in a very different light balance between the two throughout. It's almost like Av mode somewhat 'goes out the window' when you add a flash on, it's really not 'Av mode' anymore when all 3 exposure triangles remain fixed from ISO 100-1600.
Also, to get back to the Lensbaby/Manual glass, when in Av mode and you have a flash attached, it slaps it to 1/200 right, but if you menu dive and change Flash Sync Speed (to something less than 1/200) it's still not reflected in Av mode (obviously is in X mode). And as you say in Manual mode you can adjust it, I was just curious as to where this 1/200 came from for Av mode when those kinda lenses were attached.
Up till now I have not messed around with Flash Sync settings much, P-TTL, HSS and Manual. Second Curtain I haven't had the need to try yet. I did use Tv mode to great success at a dance recently and dropped the shutter speed down to 1/5th but I had the flash in 'Normal' mode, ie first curtain? Whereby the flash fired first and then took longer to complete the shot. I tried it the other way around, but I found it harder to 'capture the moment' as the flash is firing after you see the moment you want to capture. I understand where it could be useful however, just thus far have not encountered the need for it. So when you say 'enabling slow sync' what exactly is this?
Thanks again Steve,
Bruce
