The rule of thumb goes like this:
- All Pentax-brand flashes are voltage-safe with all Pentax K-mount cameras (Edit: with possible exception of the early 1970s AutoRobo model)
- All Pentax-brand flashes are broadly compatible (dedication, flash automation, etc.) with all Pentax K-mount cameras to the extent of their shared features. In some cases, that may mean manual flash only with little or no dedication.
That last is the sticky point, but may provide some happy surprises. I regularly use an AF280T with my K-3. No, it does not support P-TTL, but its behavior on the K-3 when used in either of its "Auto" (auto thyristor) modes includes working with the camera to set appropriate shutter speed and aperture. My review of the AF280T provides details (
LINK).
The flip side is that several legacy Pentax flash have features that are closely tailored to camera models being sold at the time the flash was made. The most difficult case being some fairly sophisticated models that support TTL (digital protocol only) and manual modes only. Probably the most notorious being the AF500FTZ and AF220T which are broadly incompatible, feature-wise, with both manual focus film cameras and dSLRs (except *ist D/DS/DS2).
Originally posted by Bui Can I try them first to learn some basic things about using flash, and what would I miss using them instead of purchasing an average modern one?
There is no harm in using the AF220T or AF400T on your Pentax dSLRs. The AF400T in "auto" modes should behave much the same as my AF280T (see above), meaning that it should be quite usable.* The AF220T is TTL (digital protocol) dedicated and will operate as manual flash only on your dSLRs. The manual for the AF400T is available at the Pentax Manuals site (
LINK) and that for the AF220T is probably at the Butkus site (
LINK). What you miss relative to modern flash is convenience (huge), P-TTL exposure automation, and ability to act as optical master/controller/slave for off-camera operation.
* Note that you will require the 4P Sync Cord B or similar for dedicated hot shoe use. I would experiment with how it behaves in the various exposure modes when using "auto" and suggest Tv or M modes. Using the PC sync only, "Auto" flash exposure will still work, but will require manually setting the flash.
