Originally posted by Kobie HI all,
3) Manual only or TTL: WIll TTL data be sent to the TT600 slave from the TT350p master?
It's sent, but the TT600 won't grok it; it's non-TTL. If you want TTL with an off-camera speedlight, then you'd need another TT350P, a TT685-C with its firmware updated to grok P-TTL, a V860II of any flavor firmware updated to grok P-TTL, or a V1-P.
Quote: The price of the TT600 is pretty much the same as the Xpro-P which is why I'm tossed up here...
<grin>. Keep in mind, the TT600 has a few drawbacks vs. a TT685/V860II/V1, aside from the lack of TTL. It cannot be firmware updated, so newer features that have been added with firmware updates won't work with it (e.g., ID codes or turning off that blinking "slave active" status LED). It also cannot be remotely zoomed.
And the TT350-P vs. an Xpro-P, has fewer features as a radio transmitter. It can only control three groups (instead of 5), the radio master UI is a lot more of a PITA vs. the one on the XPro, and the XPro can do TCM (TTL locking). In addition, a
Flashpoint R2 Pro II-P (which also costs $70), has bluetooth app control, so you can use your phone to adjust/fire your flashes, as well as the SCAN function which automatically sets the channel to the least-crowded one.
But yeah, the TT600 / TT350P combo will work for what you want.
